Author Topic: 21psi yeeeaaaahhhh hhhhhaaaaaaaaaaaaaaaa  (Read 5910 times)
Offline Wazzzer
  • Moderator
  • Golf GTI 1.8T AGU
Re: 21psi yeeeaaaahhhh hhhhhaaaaaaaaaaaaaaaa
« Reply #30 on: 26 May 2010, 19:39 »
ah always wondered what that thing was  :grin:
Offline RTechUK
  • R-TECH OFFICE 01455 617233
« Reply #31 on: 29 May 2010, 11:30 »
Email me some logs of the requested and actual load,
 01455 617233
Offline linz
  • vee-dub
« Reply #32 on: 29 May 2010, 11:34 »
sounds good and nick i shall be saving those pennies an making tht trip to see you hopefully sooner rather thn later
Offline northeast_gti-t
  • "1.8T AGU"
« Reply #33 on: 30 May 2010, 00:05 »
mines now hitting the same figure  :wink:
2000 Mkiv GTi 1.8T AGU
Offline Wazzzer
  • Moderator
  • Golf GTI 1.8T AGU
« Reply #34 on: 30 May 2010, 10:09 »
running 18-19psi now but think I've still got a leak somewhere so that needs a bit more investigating  :smiley:
Offline RTechUK
« Reply #35 on: 30 May 2010, 10:15 »
Getting there then,  What have you done to get to 19psi?   Can you do a log of the requested and actual load, this will show if requested boost is being met.#
Nick
 01455 617233
Offline Wazzzer
  • Moderator
  • Golf GTI 1.8T AGU
« Reply #36 on: 30 May 2010, 12:06 »
I adjusted my throttle cable  :grin:
I wedged it open full throttle on the pedal and had a look inside the throttle housing and the butterfly was only open half way. Pulled my cable tight and clipped it there, give it a quick run with VAG COM to adapt it and voila!
The cable is on it's last legs though so ordered another. Will get some logs this week and pop them up. I can find the block for actual load on VAG COM, any idea what block I should be logging for requested? (AGU)
Offline RTechUK
« Reply #37 on: 30 May 2010, 13:06 »
Good lad, you can have a job soon..lol
Actual and spec blocks 025, do some cvs logs and a a real time graph with long 4th gear pull, then take a snap shot of the screen and save it in mspaint.   By taking thw snap shot you will get a visual picture of what the boost and N75DC% is doing.
Nick
 01455 617233
Offline Wazzzer
  • Moderator
  • Golf GTI 1.8T AGU
« Reply #38 on: 30 May 2010, 15:01 »
excellent thanks mate, will do them this week sometime
