Author Topic: 21psi yeeeaaaahhhh hhhhhaaaaaaaaaaaaaaaa  (Read 5913 times)
Offline MaXXeH
  • Golf MK5 GTI
Re: 21psi yeeeaaaahhhh hhhhhaaaaaaaaaaaaaaaa
« Reply #20 on: 24 May 2010, 19:19 »
what do i need to go into and i will do it tonight
Offline Wazzzer
  • Moderator
  • Golf GTI 1.8T AGU
« Reply #21 on: 24 May 2010, 19:41 »
cheers fella, just log block 1 for a full throttle run, should give the same readings as the log I posted
Offline Wazzzer
  • Moderator
  • Golf GTI 1.8T AGU
« Reply #22 on: 25 May 2010, 17:27 »
anyone?
Offline MaXXeH
  • Golf MK5 GTI
« Reply #23 on: 25 May 2010, 17:40 »
doing it tonight..  :cool:
Offline MaXXeH
  • Golf MK5 GTI
« Reply #24 on: 25 May 2010, 18:35 »
Here you go
20.7   2360   0.95   8.7   22.5
21.08   2360   1.3   14.3   15.8
21.47   2320   4   35.2   27.8
21.85   2520   5   56.9   21.8
22.24   2680   6.55   72   17.3
22.6   2880   8.9   84.2   14.3
22.99   3160   11.25   84.2   15
23.37   3440   10.95   84.2   15
23.76   3760   10.15   84.2   18
24.12   4080   10.2   84.2   20.3
24.49   4400   9.75   84.2   22.5
24.86   4720   9.55   84.2   24
I hope this helps
Offline MaXXeH
  • Golf MK5 GTI
« Reply #25 on: 25 May 2010, 18:37 »
Second log
46.34   2360   5.4   51.6   18.8
46.7   2520   6.6   54.3   12.8
47.1   2760   8.55   55.1   12
47.48   3040   8.05   54.3   18
47.86   3360   8.4   73.3   18
48.23   3640   12.45   84.2   16.5
48.62   4200   11.5   84.2   19.5
49.02   4600   11   84.2   21
49.4   4960   10.55   84.6   21.8
49.8   5280   10.6   84.2   24
Offline Wazzzer
  • Moderator
  • Golf GTI 1.8T AGU
« Reply #26 on: 25 May 2010, 18:40 »
nice one mate, much appreciated
full throttle looks to be an angle of 84.2 degrees then, not my 42...
I'll try a throttle alignment later and a few other bits to see if it cures it. Will start another topic to see if anyone can shed some light on what it could be...fr
Offline gti_shaun
« Reply #27 on: 25 May 2010, 18:49 »
could the altitude sensor be my problem then anyone? NICK?? http://www.golfgtiforum.co.uk/index.php?topic=155729.0
Offline Wazzzer
  • Moderator
  • Golf GTI 1.8T AGU
« Reply #28 on: 25 May 2010, 19:23 »
what does the altitude sensor do and where is it?
Offline gti_shaun
« Reply #29 on: 25 May 2010, 23:06 »
its right hand side of engine bay  at the back it clips onto the bulk head, im guessing it picks up the the height you are at to calculate the pressure, thats a rough guess.
