Author Topic: Wazzzer's 1.8T... Lots of updates  (Read 403270 times)
Offline Wazzzer
  • Moderator
  • Golf GTI 1.8T AGU
Re: Wazzzer's 1.8T... US side markers fitted
« Reply #760 on: 03 June 2015, 19:21 »
Had this spare rubstrip with cut outs for the US side markers kicking about at work for ages so decided to spray and fit it at the weekend along with my smoked markers and LED bulbs. So I turned my parents garage into a ghetto spray shop again...
primed
Loads of coats of colour and lacquer later
Markers bonded in
The hole I had to carve in the bumper with a pad saw for wiring and to stop the back of the light clashing
Rubstrip fitted
and with ignition on...
:afro:
« Last Edit: 03 June 2015, 21:46 by Wazzzer »
Offline Rhyso
« Reply #761 on: 04 June 2015, 18:54 »
Still tinkering then?? :grin: :smiley:
Offline Wazzzer
  • Moderator
  • Golf GTI 1.8T AGU
« Reply #762 on: 04 June 2015, 19:40 »
Yeah got a few bits to do it it this summer then I'm drawing a line under it, not much else I can do other than abuse it daily lol
Offline Wazzzer
  • Moderator
  • Golf GTI 1.8T AGU
Re: Wazzzer's 1.8T... inverted cluster displays
« Reply #763 on: 19 July 2015, 10:28 »
Had a play with my clocks recently and inverted the mileage/clock display
I still want to make the background darker so only the digits show in red but it will do for my first attempt :afro:
« Last Edit: 19 July 2015, 10:39 by Wazzzer »
Offline Rhyso
« Reply #764 on: 19 July 2015, 13:18 »
You've got too much time on your hands  :whistle:
Offline Wazzzer
  • Moderator
  • Golf GTI 1.8T AGU
« Reply #765 on: 19 July 2015, 16:53 »
 :kiss:
Nice to finally have some  :wink:
Offline Wazzzer
  • Moderator
  • Golf GTI 1.8T AGU
« Reply #766 on: 16 August 2015, 22:36 »
This happened the other day...
More pics to come :afro:
Offline Wazzzer
  • Moderator
  • Golf GTI 1.8T AGU
Re: Wazzzer's 1.8T... Votex skirts fitted
« Reply #767 on: 22 August 2015, 09:35 »
A few more pics as promised
Hopefully looking to get my Coilovers fitted today, if I have time I'll get the rear beam on too
Offline Wazzzer
  • Moderator
  • Golf GTI 1.8T AGU
« Reply #768 on: 25 August 2015, 22:23 »
Fitted the front coilovers at the weekend along with new top mount bearings and 4motion brake hose brackets
Front end has dropped about another 10mm and is pretty much where I want it to be now, just the rears to fit when I get the chance, hopefully this weekend
You can just about see the coilover covers I have fitted to keep the threads nice and clean in this pic
Also made the switch to the later coil packs a permanent feature...
Offline Wazzzer
  • Moderator
  • Golf GTI 1.8T AGU
« Reply #769 on: 07 September 2015, 22:28 »
Managed to get a lot done on the car this week; rear beam swap with new stub axles and bearings, 256mm rear discs and brand new calipers fitted, new revision handbrake cables and clips and the rear coilovers added too.
Unfortunately I did my usual and forgot to take my camera for some pics but I need to go back up to my mates lock up with the car soon to re bleed the brakes as they don't feel as sharp as they should after the 300 mile round trip I did yesterday. First impressions with the FKs are that they're not as bad as I thought they were going to be. They're definitely a bit softer than my spring/shock setup I had but this is probably a good thing with it being a family car :laugh:
She din't miss a beat though and returned a nice 45mpg which I was really happy with.
I've also got a bit of enthusiasm back for the wheels and have started painting the rears, one is ready for clear coat and the other is in primer so getting there. Would be nice to get them both done by the end of next week but we shall see what pops up in the meantime.
One small thing I did do today was visit the scrapyard and I found some needles which I haven't seen used in a Golf cluster before so I thought why not...
From this
to this
I quite like them, and the good thing is I've got the option to change whenever I feel like it :afro:
Apart from the wheel I don't really have much planned for the car other than a full laser alignment and possibly having the centre box removed from the exhaust but I quite like the way it sounds at the mo. I do need a remap but that will probably be the other side of Xmas
I'll get some pics once I've got her on axle stands again
