Author Topic: Serious Ipod conflicht with RNS510  (Read 4481 times)
Offline ErikGTI
« on: 01 May 2010, 15:32 »
I am lost......
I use an Ipod Classic and today when I switch the ignition on it said...no Media Device....
I tried everything...but no....
I took the Ipod loose and it seems to be stuck on a song in "Pause"-mode....there is not a thing I can do to reset it or switch the Ipod off.....help... :sick:
I'LL BEAT YOU TO THE BBC STUDIO........
Offline Steve30
  • Ed30 .
Re: Serious Ipod conflicht with RNS510
« Reply #1 on: 01 May 2010, 15:54 »
I am lost......
you need to press the menu button for 10 sec on the iPod with the other finger pressed on the wheel! If not google iPod stuck and you get your result there . Mine did the same last week fixed now.
Tiguan quicker than the Golf
Offline ErikGTI
« Reply #2 on: 01 May 2010, 15:54 »
I gave the Ipod a hard reset (menu button en middle button pressed at the same time) and I am in business again....
I wonder how we can make the Ipod Media less faulty...eg before you switch off the car change to HDD or CD or SD... :huh:
Any ideas/experiences...cause this is bound to happen a lot..... :sick:
Offline nr123
« Reply #3 on: 01 May 2010, 18:29 »
Sounds more like your iPod is at fault than your car
Offline p3eps
« Reply #4 on: 01 May 2010, 19:18 »
I've had mine lock a couple of times...
I simply lift the armrest, unplug the media cable, then replug it back in.  Wait 30 seconds, and its good as new.
Its only happened twice, and both times have been when the iPod hasn't been used for 3 or 4 days.
Golf R... 3 door, DSG, Leather, Reflex Silver, Black 19" Talladega Wheels, ACC, Parking Sensors, RNS510 with Dynaudio, Reverse Camera, Luxury Pack, Cruise Control & Fiscon Bluetooth.
Offline ErikGTI
« Reply #5 on: 01 May 2010, 19:40 »
hi p3eps i tried that a few times...but nope...
anyway i keep you informed...
BTW I have the coverflow of my Ipod on so I expected the RNS to start with album A but NOPE it gives me all the track of all 999 albums starting with A....I decided on the spot that that's okay with me..... :lipsrsealed:
Offline p3eps
« Reply #6 on: 01 May 2010, 22:25 »
I'm using an old 5th Gen iPod - so its not advanced enough to have coverflow!
Offline wilobach
« Reply #7 on: 02 May 2010, 02:09 »
i have the new version of a i pod touch and it freezes about 2 times out of ten i get in the car and allso the track name does not change some times whith the song
realy anoying i have to unplug the ipod and some times turn off thge radio and the iopd and start again
and all woks for some time again, but the ipod works ffine on my fathers range rover whith nbo gliches at all so its not the i pod
allso the unit i have is the rcd510
Golf R, 3dr, rising blue, 19" wheels Black, dynaudio, leather seats, revo remap
Offline ErikGTI
« Reply #8 on: 02 May 2010, 08:14 »
If you search over the net you unfortunately have to come to the conclusion that the Ipod and the RNS510 are not really compatible....
I wonder what is worse....not compatible....or "not really" compatible.....I think in the long run I will go back to a 32 Gig USB stick....  :evil:
Offline AlanH
« Reply #9 on: 02 May 2010, 10:09 »
I have a similar problem with my iPod Classic 80GB and my RCD510. Usually happens if I haven't driven the car for a couple of days. I have a suspicion that the iPod battery drains whilst it's connected to the RCD510, even with the ignition turned off. When the iPod battery is flat, the RCD510 won't recognise it until it has some degree of charge.
Mk7 GTD | 3-door, Carbon Grey, Keyless, Dynaudio, Pano roof.
