Golf mk2
16v MK2 GTI cold start help required
Topic: 16v MK2 GTI cold start help required (Read 3976 times)
walchy01
22 April 2010, 21:44 »
Hi all
The Golf will start but not tickover from cold, i need to rev it at 1500 RPM till it warms thru a little then it's runs like a dream, although does seem to idle at around 1300 RPM when upto to temp, is that normal or too high.
Any help or advice most welcome.
Thanks
tomsdubs
Re: 16v MK2 GTI cold start help required
22 April 2010, 22:50 »
Get a new ISV fitted or atleast try cleaning up your current one.
rubjonny
10k hero
Hello, my name is John and I'm a dub addict.
23 April 2010, 09:10 »
check the wiring to the 3 sensors on the side of the head, and make sure isv buzzes with the ign on
Sam
Sam I am
23 April 2010, 13:12 »
I am having the same problem but have just fitted a brand spanker of an isv...
sprout99
Here all the time
25 April 2010, 21:09 »
check breather hoses for leaks
25th Anniversary TDi - PD
Oak green mk2
V50 D5 Sportwagon
walchy01
26 April 2010, 16:26 »
Checked those matey, all connected.
emery1990
Reply #6 on:
27 April 2010, 18:25 »
Same, mine stalled this morning, had to rev it a bit to make it not stall. Did the ISV work? not that i know what it is!
RWMT
16v
Reply #7 on:
27 April 2010, 19:25 »
Take this little screw out...
...give it a clean, and job's a good 'un (hopefully)
emery1990
Reply #8 on:
27 April 2010, 19:49 »
Just took the screw out, i wiped off some dirt from it ( black oily). should it be dirtier than this to cause stalling when cold?
Neo Badness
Feet are for pedals
Reply #9 on:
27 April 2010, 19:50 »
Quote from: RWMT on 27 April 2010, 19:25
Remember how many turns it takes to get it out as you'll have probs if you don't put it back in right, would also recommend ISV cleaned with carb cleaner, dry it then refit. ISV is the cylindrical thing on the right hand side of the inlet manifold. Has an electrical connection and two pipes connected to it.
Golf mk2
