Author Topic: Dom069 - My 8v Story So Far - Deposit Taken :(  (Read 552948 times)
Offline dom
  • Back in a Mk4
Re: Dom069 - My Mk3 Story So Far!
« Reply #60 on: 27 April 2010, 22:55 »
top work on the rust fight so far!  :smiley:
Cheers! :afro:
It's gonna take a lot of work still! I'm happy with how it is so far, at first i thought i'd bitten off more than I could chew!  :embarassed:
Then I told myself to man up and get on with it!  :laugh:
Offline bmw156
Re: Dom069 - My Mk3 Story So Far + Removing the rust!!!
« Reply #61 on: 27 April 2010, 23:09 »
the door - rust wise isnt bad, you did the right thing with filler and paint etc. i suspect when you remove your masking tape you will have a lip, which is a b!tch to get rid of. lol
and the wing, the rust WILL come back, i went down your route with my nova. and a year later the rust was back. if i were you, spray this now, get it looking good. but always look out for a wing. as your always chasing the rust.
if it was on part of the chassis. you would of have to cut it out, and plate it, welding it in etc etc.
Offline SoundillusioN
« Reply #62 on: 27 April 2010, 23:11 »
Cheers! :afro:
agree!... i thought that about my electrics! got a lot still to do to.  well you've done a great job so far and you know that you defo not made it worse!
Offline dom
  • Back in a Mk4
« Reply #63 on: 27 April 2010, 23:14 »
Yeah I know it'll come back, I got rid of as much as I could see but who knows how much of the damn stuff is lurking behind the scenes!  :angry:
It'll do the job for the moment though and as SoundillusioN said it's def not made it worse!  :smiley:
Offline bmw156
« Reply #64 on: 27 April 2010, 23:18 »
yeh i agree, you have halted it for a while.
the reason why it rotted is because the dirt was all sitting there.
make sure you clean out all traps like this, as dirt holds water so makes it rot alot quicker :)
keep up the good work.
Offline dom
  • Back in a Mk4
« Reply #65 on: 27 April 2010, 23:21 »
Yeah defo! after seeing how much crap was behind this one i'm gonna have them all off tomorrow!  :shocked:
Bellend
« Reply #66 on: 27 April 2010, 23:21 »
Is this going to be a rattle can jobbie?
Offline dom
  • Back in a Mk4
« Reply #67 on: 27 April 2010, 23:27 »
Yeah gonna see how it turns out with a rattle can, if it looks gash i'll take it to a mate's bodyshop to be done professionally!
Offline adzgti3
« Reply #68 on: 28 April 2010, 10:24 »
Good work mate, hopefully that be the end of that rust now, and cant beilve how much dirt was in yeah arch that prob didnt help towards the rust.
Nowt wrong with spraying it with rattle can , can do a great job with them.!! :cool:
Offline dom
  • Back in a Mk4
« Reply #69 on: 28 April 2010, 14:25 »
Right small update while i'm waiting for the old man to return with more paint!
Started off by removing all the masking tape etc from last night, feathered the primer into the existing paint and masked it all up again!
The sprayed 2 coats of primer along the entire of the bottom of the door and this is the result:
Once I was happy with the primer I gave it a couple of coats of Red, sanded down using 800 and then 1200 grit wet and dry paper, this is how it stands at the moment.
Gonna give it another couple of coats of top coat, and see what the finish is like, if i'm not happy i'll sand down and repray until I am!
Once it's fine i'll laquer it and see what the result is!  :grin:
