Author Topic: cambelt squeak  (Read 4167 times)
VW BUSH
Re: cambelt squeak
« Reply #20 on: 10 October 2009, 21:07 »
spray some WD (Not bucket loads) on belts while running if the noise goes then its just belt squeel, if it dont you need to have a look. :smiley:
Offline DarnPB
  • Formerly Darnpistonbroke
Re: cambelt squeak
« Reply #21 on: 10 October 2009, 23:03 »
As said before, it sound like another belt squeaking or a pulley, possibly from the water pump, alternator or powered steering pump.
Offline Khare
  • The bear that khares
Re: cambelt squeak
« Reply #22 on: 10 October 2009, 23:49 »
I wouldn't. I think its been said before that any oil based stuff eats rubber.
VW BUSH
Re: cambelt squeak
« Reply #23 on: 11 October 2009, 14:02 »
Tiny mist to stop the belts squeeling while you listen for rumbly bearings and shagged pump aint gonna hurt, trust me :smiley:
Offline shepgti
Re: cambelt squeak
« Reply #24 on: 12 October 2009, 12:17 »
noise is definately coming from the pas pump area, how hard a job is it to replace the pump as my steering is very heavy..
Re: cambelt squeak
« Reply #25 on: 12 October 2009, 12:31 »
Easy enough to sort
Offline axewielder
  • 95 dragon 8v
Re: cambelt squeak
« Reply #26 on: 12 October 2009, 12:36 »
an aa man did this to a pajero i was in when it broke down+ he said it was fine, does it all the time
Offline shepgti
Re: cambelt squeak
« Reply #27 on: 12 October 2009, 14:22 »
with rferance to changnig the pas pump, is it a case of draining the fluid and bolting on/off pump?
Re: cambelt squeak
« Reply #28 on: 12 October 2009, 15:11 »
Yes, plus you may / will need to bleed the sytem when it is all back together.
Offline shepgti
Re: cambelt squeak
« Reply #29 on: 12 October 2009, 15:16 »
whats there left to bleed if i have drained it before removing the old pump??
