Author Topic: cambelt squeak  (Read 4145 times)
Offline shepgti
Re: cambelt squeak
« Reply #10 on: 10 October 2009, 14:41 »
Since its a toothed belt it would have to be really loose to squeal, but then again you havent said what the noise is like :huh:
is just a contant squeeking noise.. i just assumed it was a belt of some sort
Offline harlemex
Re: cambelt squeak
« Reply #11 on: 10 October 2009, 14:50 »
I get a squeeky pulley belt sometimes when starting from cold, soon goes once the engine is warm. I reckon one of  your pulley belts needs tightening up. Try feeling the tension of your pulley belts by pushing and pulling on them
Offline shepgti
Re: cambelt squeak
« Reply #12 on: 10 October 2009, 15:06 »
im no mechanic.. where and what is the pulley belt?
gtigolfthree
Re: cambelt squeak
« Reply #13 on: 10 October 2009, 15:20 »
He means your fan belts for the alternator, water pump, power steering etc. :smiley:
Offline robz
Re: cambelt squeak
« Reply #14 on: 10 October 2009, 15:29 »
i had all my belts done not too long ago... might get him to nip em up when he has the car next week for mot!
we could bring the josho trick up here, lol
Offline christomk3gti
Re: cambelt squeak
« Reply #15 on: 10 October 2009, 16:40 »
I have same annying sound. but it only happens every now and again when i first start the engine. then it eventually goes as it warms up.
I will find out what it is eventually  :smiley:
Black 8v GTI............. Whats a Waffle Valve?
adamrob69
Re: cambelt squeak
« Reply #16 on: 10 October 2009, 18:21 »
aux belt, alternater bearings.
i have a sort of noise, wouldnt say it was a squeek but not too disimilar. its coming from the aux belt area, the belt is fine though so not worried. my 1.4 did it also, and most mk3s i have walked past have had the noise! i just ignore it.
gtigolfthree
Re: cambelt squeak
« Reply #17 on: 10 October 2009, 18:32 »
Yes the water pump too, if you over tighten the belt it f**ks the bearings.
Offline Khare
  • The bear that khares
Re: cambelt squeak
« Reply #18 on: 10 October 2009, 18:40 »
to replace the circlip pliers you can get a fork, and bend out both the outer "spikes" whatever you call them lol.
Cambelt should twist 90 degrees at the longer end (between cam pulley and intermedate pulley)
Offline Matty-MK3
  • Automatic boats FTW.
Re: cambelt squeak
« Reply #19 on: 10 October 2009, 20:56 »
:grin:
He helped me out with mine, used a small allen key, into one of the holes and pushed it down against the nut, then did the nut  up with a spanner then torqued it up.
As Khare said, the cambelt should twist 90 degree's on the longer end.
Golf MK3 1.8 auto and I didn't pay a grand for the "priveledge" :grin:, auto windows all round and a AC. Oh and I've got a luggage net you pricks!
Does that make my willy look bigger?
Oh yeah it's called Helda or something....
