Author Topic: cambelt squeak  (Read 4140 times)
Offline shepgti
cambelt squeak
« on: 10 October 2009, 13:52 »
can anything be done about a noisey cambelt?the belt is only a few months old so its not a worn belt  :undecided:
Offline AudiA8Quattro
Re: cambelt squeak
« Reply #1 on: 10 October 2009, 13:53 »
Was the tensioner done as well?
Have you checked the belt tension?
Offline shepgti
Re: cambelt squeak
« Reply #2 on: 10 October 2009, 13:55 »
tensioner was done aswell, has been silent since it was done has just decided to start being noisey  :angry:
Re: cambelt squeak
« Reply #3 on: 10 October 2009, 13:57 »
Re-check the belt tension.
Offline Khare
  • The bear that khares
Re: cambelt squeak
« Reply #4 on: 10 October 2009, 13:57 »
+1. You might find it has "loosened" up since it was fitted.
Offline robz
Re: cambelt squeak
« Reply #5 on: 10 October 2009, 13:58 »
good thread to start actually, beat me to it...
mines more of a squeek..?
anyone with awesome advice??
Offline shepgti
Re: cambelt squeak
« Reply #6 on: 10 October 2009, 14:04 »
how can i tighten the tnesioner without using right angle circlip pliers?
Offline harlemex
Re: cambelt squeak
« Reply #7 on: 10 October 2009, 14:26 »
Cambelts dont normally squeek. The noises you are hearing are likely to be your pulley drivebelts.
gtigolfthree
Re: cambelt squeak
« Reply #8 on: 10 October 2009, 14:29 »
It will only squeak if you get oil or fluid on it. Shouldn't be possible if the covers are fitted properly.
Offline harlemex
Re: cambelt squeak
« Reply #9 on: 10 October 2009, 14:34 »
Since its a toothed belt it would have to be really loose to squeal, but then again you havent said what the noise is like :huh:
