Author Topic: Hunting! - Vacuum Pipes!  (Read 4749 times)
Offline Len
« on: 11 June 2009, 20:03 »
Well I replaced the vac pipe up from manifold to ECU and a secondary one from MAF vac up to god knows where! That seems to disappear behind the washer bottle then up into wing!
Any way I now have very bad "hunting" at idle in fact it wont idle any lower than 1200 revs!
So I tried swapping on the K&N again and changed over the throttle body! And combinations!
I think there was some threads about this before or similar traits but cant find em!  :angry:
So where to look? I'm thinking it must be a sensor? But which one? MAF?
www.sas.org.uk
www.the-ace.org.uk
Offline Khare
  • The bear that khares
Re: Hunting! - Vacuum Pipes!
« Reply #1 on: 11 June 2009, 20:05 »
only way to know for sure is vagcom. Is the throttle body nice and clean?
Offline Len
« Reply #2 on: 11 June 2009, 20:30 »
Yep both are! One being more polished than the other!
Yes I need Vagcom!
www.sas.org.uk
www.the-ace.org.uk
Offline spunkymonkey
  • Tepidly moist! That's what that is!
« Reply #3 on: 11 June 2009, 20:39 »
If its hunting around 1200rpm sounds like a vac leak.
When you say it goes god knows where, is it connected to something at both ends? If not block it off and try it.
Offline Len
« Reply #4 on: 11 June 2009, 20:44 »
Yes I agree! But where? Cant see any other hoses and no spare places to connect one!
Checked with another 16v and have same hoses!
Now all hoses are new!
This one from the T piece of the MAF hose goes to another T then by white plastic pipe behind the washer bottle then in under the wing and I cant see where it goes!
Yes I took the battery and washer bottle out!
www.sas.org.uk
www.the-ace.org.uk
Offline davero
« Reply #5 on: 11 June 2009, 21:58 »
Have you changed the one under your inlet manifold.? The maf is the one from the t.b. to the ecu. Have you a pic of the other one?
Offline Paul86S2
« Reply #6 on: 11 June 2009, 22:13 »
Confused on this - you haven't got a MAF so what part are you referring to as the maf?
On my 16v throttle body I have a vacuum pipe going to the airbox for the cold start air diverter valve (if you've got a induction kit this will need to be blocked off. A second larger one going to the valve on the charcoal canister. From the manifold above the VW sign I have a vacuum pipe going to the ecu under the passenger side scuttle panel. And below the throttle body from the manifold I have a short vacuum pipe that goes to the fuel pressure damper on the fuel rail. A large vacuum pipe goes from the back of the manifold to the brake booster.
Not sure what vacuum pipe goes under the water bottle and battery, have you got cruise control?
Paul
Offline davero
« Reply #7 on: 11 June 2009, 22:21 »
Paul
This is the map sensor hose, the equivalent to the maf on a 16v.
Offline AudiA8Quattro
« Reply #8 on: 12 June 2009, 00:00 »
Len, did you replace the throttle body gasket when you removed it?
Offline Diamond Hell
  • Opinions я Us
« Reply #9 on: 12 June 2009, 00:02 »
There is clearly only one solution to this problem.
A Golf3 with a fault is like a horse with a broken leg.  There's only one option open to you.
