Author Topic: Hunting! - Vacuum Pipes!  (Read 4755 times)
Offline axewielder
  • 95 dragon 8v
Re: Hunting! - Vacuum Pipes!
« Reply #30 on: 16 June 2009, 13:17 »
mine was the crank sensor+ it started+ ran fine til it warmed up then would keep stalling. Also car will run without hall sender pluged in, just not optimally. 2l 8v btw
Offline christomk3gti
« Reply #31 on: 16 June 2009, 13:27 »
well mine doesnt really stall much at all, in 8 months its happened twice. I drive it all the time aswell.... But the rev counter when i put clutch down does drop to about 500... then jump to 800...(and as it drops to 500 u can feel it wanting to die) (has twice) I just hope its just the throttle body needing a clean, or the spark plugs. Because if its a sensor, then I am ashuming it will be more severe?
regards.
Black 8v GTI............. Whats a Waffle Valve?
Offline thai-wronghorse
  • mk1 Seat Leon FR TDI
« Reply #32 on: 16 June 2009, 20:30 »
Ditto. the crank speed sensor may well be breaking down and not fully shot as yet.
