Author Topic: Electrical wiring for boost gauge - finally completed  (Read 11610 times)
Offline T_J_G
Now as you all know I fitted my boost gauge today but left the wiring. I have two wires one going to earth and one going to the dimmer switch.
So i'm guessing the earth ones just goes to a metal chassis part or does it connect into another loom? And where abouts does the one going into the dimming switch do i have to cut a wire and put a scotchblock in or similar :S Couldn't find any guides that covered it!
I'm useless with electrics.
Thanks
Tim
« Last Edit: 26 April 2009, 11:44 by T_J_G »
Offline Rhyso
Re: Electrical wiring for boost gauge
« Reply #1 on: 22 April 2009, 21:30 »
grey / blue wire in the headlight switch :afro:
earth to an earthing point - there's one under the steering wheel IIRC
Offline richw911
Offline northeast_gti-t
  • "1.8T AGU"
« Reply #3 on: 22 April 2009, 21:33 »
Thanks
Tim
tim the earth wire connects to a common point under the dash there are some earths there and iirc there is a spare connection that vw kindly left  :wink: use this for the earth and the one to the dimmer switch which is iirc the blue/grey wire either solder in or use a scotch lock hth
2000 Mkiv GTi 1.8T AGU
  • "1.8T AGU"
« Reply #4 on: 22 April 2009, 21:35 »
beat me to it rich  :wink: i remember these links cos i have had a read of them ready for installing my boost gauge next week hopefully  :smiley:
Offline Rhyso
« Reply #5 on: 22 April 2009, 21:35 »
is there an echo in here?  :rolleyes: :tongue:
  • "1.8T AGU"
« Reply #6 on: 22 April 2009, 21:41 »
pmsl i think there is  :grin: :rolleyes:
Offline T_J_G
« Reply #7 on: 22 April 2009, 22:06 »
Cheers guys I think I'm a bit better clued up, need to grab some scotchblocks and ill have a look at it tomorrow!
  • "1.8T AGU"
« Reply #8 on: 22 April 2009, 22:10 »
nice one  :wink: let us know how you get on :afro:
Offline Wazzzer
  • Moderator
  • Golf GTI 1.8T AGU
« Reply #9 on: 22 April 2009, 22:11 »
why don't you ask me nicely and I'll open this package with your loom in and I'll solder on 2 wires for your boost gauge connection before it gets sent to you
