Author Topic: Electrical wiring for boost gauge - finally completed  (Read 11612 times)
Offline northeast_gti-t
  • "1.8T AGU"
Re: Electrical wiring for boost gauge
« Reply #10 on: 22 April 2009, 22:19 »
why don't you ask me nicely and I'll open this package with your loom in and I'll solder on 2 wires for your boost gauge connection before it gets sent to you
there you go tim sounds good that and it will just need you to connect straight up  :wink: i'd be the first to tell you that wazzers looms are spot on mate i fitted jonnys bora vent loom and was impressed :afro:
2000 Mkiv GTi 1.8T AGU
Offline T_J_G
« Reply #11 on: 23 April 2009, 09:01 »
That would be kind but the back of the gauge is sealed. I ideally want to get it sorted today as well. Thanks anyway :)
Offline T_J_G
« Reply #12 on: 25 April 2009, 14:37 »
Riiight guys,
This is the dummer switch and you can see the grey blue cable (although due to the light you can only spot it as it enters the connecter, so I need to cut this cable and attach the boost gauge cable. Does that mean all 3 cables are connected together?! The earth one I can manage but this confuses me!
Offline richw911
« Reply #13 on: 25 April 2009, 14:43 »
Yeah just cut into it and add the boost illumination wire  :wink:
Offline T_J_G
« Reply #14 on: 25 April 2009, 14:45 »
You're a star I may go and hack that apart now then :grin:
Offline T_J_G
« Reply #15 on: 25 April 2009, 18:12 »
Right done it, but the backlight doesn't seem to work. I've tried using the button that changes colours but nothing :(
Offline monzablue16v
« Reply #16 on: 25 April 2009, 18:21 »
Are your headlights turned on?
Offline T_J_G
« Reply #17 on: 25 April 2009, 18:24 »
yep
Offline Wazzzer
  • Moderator
  • Golf GTI 1.8T AGU
« Reply #18 on: 25 April 2009, 19:19 »
strange, is there only a +ve and -ve feed for the gauge? No other wires?
Offline T_J_G
« Reply #19 on: 25 April 2009, 19:23 »
There' an illumination wire and a ground wire. I'll have to check when it's dark tonight.
