Author Topic: Electrical wiring for boost gauge - finally completed  (Read 11649 times)
Offline T_J_G
Re: Electrical wiring for boost gauge
« Reply #20 on: 25 April 2009, 19:38 »
From SWG:
Hi
The gauge needs a solid live feed not one from the dimmer switch, we have not had any faulty NSP gauges, please disconnect the feed leave for a few minutes then reconnect checking all the connections are correct and solid , it should work ok.
Offline richw911
« Reply #21 on: 25 April 2009, 20:04 »
From SWG:
Hi
Mines on a dimmer but i have a different gauge to you  :undecided:
Offline dai-cymru
  • 1989 MK2 16V
« Reply #22 on: 25 April 2009, 20:15 »
run some test wires from the battery pos and neg to test   :smiley:
Offline T_J_G
« Reply #23 on: 25 April 2009, 22:59 »
but i only have 1 wire and an earth :s
Offline T_J_G
« Reply #24 on: 26 April 2009, 10:06 »
Going to use the permanent wire now, it's the grey one isn't it?
This is a pic i took last night...
Offline Wazzzer
  • Moderator
  • Golf GTI 1.8T AGU
« Reply #25 on: 26 April 2009, 10:24 »
yeah that kinda makes sense, the rheostat control might throw the voltage out.
Glad you've got it sorted mate  :cool:
Offline T_J_G
« Reply #26 on: 26 April 2009, 10:56 »
It's not sorted yet, that's using the dimmer wire. I need to use the permanent wire as the backlight doesn't work, should be able to change colours.
Offline T_J_G
« Reply #27 on: 26 April 2009, 11:39 »
Haha!
I've only gone and done it, I took it out of the dimmer wire and put it into the grey permanent wire and bobs my uncle :) Also it only comes on with the lights :) Looks quite smart, not keen on the mount though. Thanks so much for all your help!
Some pics, bearing in mind it was sunny!
I'll get some pictures of the different colours tonight :)
Offline northeast_gti-t
  • "1.8T AGU"
Re: Electrical wiring for boost gauge - finally completed
« Reply #28 on: 26 April 2009, 11:52 »
nice one tim  :smiley: glad your sorted with your wiring etc just hope i can tap mine into the dimmer circuit  :undecided: when i come to install mine are you able to change yours to the blue illumination? would look oem then :afro:
2000 Mkiv GTi 1.8T AGU
Offline T_J_G
« Reply #29 on: 26 April 2009, 11:58 »
Yeah this one has 100 different colours, I'm going to sort the colouring tonight when it's dark to get the closest match to the dash! I think mine can't go on the dimmer wire due to the different colour backgrounds. Most gauges can though I think.
Quite satisfied I did that myself actually, albeit with LOTS of help!
