Author Topic: Amp cutting out...  (Read 6569 times)
Offline Shady Pioneer
  • graphic designer.
Amp cutting out...
« on: 19 April 2009, 18:57 »
I'm taking it this is to do with me having it too loud? Set the gains too high?
I have a new 6 channel amp and have all channels bridged to 3 channels, 2 comps and a sub. I know how to set up the sound etc, just thinking is it my battery that is the problem hear as not enough juice is getting to it? Or is it the AWG wire I'm using (8AWG) which is the minimum recommended for this amp.
Any help?
Offline troublestarter
Re: Amp cutting out...
« Reply #1 on: 19 April 2009, 22:27 »
how many fuses does the amp have and what make and model
www.awesomeautomotive.co.uk<br />mobile vehicle security & audio fitting service<br />insurance accredited
Offline dTEA
  • back in an MK5
« Reply #2 on: 19 April 2009, 23:27 »
grounding issue shady??  Were you running an amp on the same ground previously etc?  A lot of amps do have protection against underload/overload
Edition 30 / T5 T32 Kombi
  • graphic designer.
« Reply #3 on: 19 April 2009, 23:29 »
It has two fuses on the amp, and an inline fuse near the battery. It's a JBL GTO 755.6 I believe. As for the grounding, my ground is solid, it's on a bolt under the rear seat, contacting a surface of bare metal :)
I never had this problem with the old amp (4 channel JBL 1004e) and using the same cables.
Offline dubbinmk3
  • ITS A VAG THING .......YOU WOULDNT UNDERSTAND
« Reply #4 on: 20 April 2009, 07:02 »
had this brfore with a monobox 4 amp on my old 306 turned out it was the battery :shocked: it would run for a little bit and then cut out and go into protection mode, then when i ran the car and started it again it would do it al over again! my battery wasnt great and the amp just killed it!
your wiring will be fine it just means ure not going to get the best out of the amp as it cant suck enough power to run full but wouldnt cause it to cut out!
the only other thing to check would be the earth as said in above post. the beat place for an earth is a seatbelt mount clean it of all paint and tighten the earth (dont forget its alot of power to get rid of)
personally if its not a good earth then that will be ure problem but if you know thats all good then id check ure battery!
hope that helps
cheers
luke awesome.audio
*ITS A VAG THING......YOU WOULDNT UNDERSTAND*
Offline dTEA
  • back in an MK5
« Reply #5 on: 20 April 2009, 20:10 »
get a free battery test???
  • graphic designer.
« Reply #6 on: 20 April 2009, 20:15 »
From whom?
Offline dubbinmk3
« Reply #7 on: 20 April 2009, 21:03 »
i think that halfords do a free check mate
  • graphic designer.
« Reply #8 on: 20 April 2009, 21:03 »
What am I looking out for then? What's bad signs etc?
Offline Yuley
  • DBP .:R32 :)
« Reply #9 on: 20 April 2009, 23:37 »
yeh pop halfords, we have a lil green machine that gives a readout what percentage of efficiancy the battery is at :)
Mk3 1.4
To
Astravan
To
Mk4 .:R32   Things just got interesting ;)
