Author Topic: Amp cutting out...  (Read 5684 times)
Offline dTEA
  • back in an MK5
Re: Amp cutting out...
« Reply #20 on: 22 April 2009, 08:02 »
daft q but have tested the actual end of the power lead going into the amp, just to make sure its getting enough feed? voltage meter would tell you... And is the remote wire stable?  When you say cutting out do you mean complete power drop out or just sound?  If just sound then its more likely to be the amp itself, and if power then still leads me to the leads...or fuse ratings?
If not i might be selling my kicker amp and kenwood 7x10's on a custom stealth shelf as i never refitted from my mk3  :grin:
Edition 30 / T5 T32 Kombi
Offline dubbinmk3
  • ITS A VAG THING .......YOU WOULDNT UNDERSTAND
« Reply #21 on: 22 April 2009, 11:51 »
i would say its either alternator or earth then, i wouldnt say its power cable not unless its earthing out on something but in that case would cause you more problems then just cutting out! if theres power to the amp and the batterys fine the voltage would never change not unless the batt didnt have enough power.
as regards to eliminating the remote cable id unplug it from the amp get a tiny bit of wire and link the remote to the 12v on the amp and try that. the amp will stay on constant so dont leave it like that just see if it stops cutting out!
if these are fine and the altenator is all good wich really it should be if ure battery was a good percentage then i would start to check the amp, maybe try it in a mates car or something, and the earth.
it could also be caused by having to smaller amp wiring as if ure asking alot from the amp the amp needs alot of power and it needs to get rid of alot of power so it trys to take as much as it needs from the batt however if ure amp cabling is to small it wouldnt be able to suck enough to get it running ie: it would cut out and go into protection mode!
hope this helps
luke@awesome.audio
*ITS A VAG THING......YOU WOULDNT UNDERSTAND*
Offline Shady Pioneer
  • graphic designer.
« Reply #22 on: 22 April 2009, 17:06 »
Thanks for the info guys, but got my old amp back in now, eventually I'll upgrade again but at the same time I'll put a bigger power cable in. I know for sure the earth is fine, as my old amp (current now) never cut out ever. :)
Offline sharki786
  • GOT BOOST??
« Reply #23 on: 24 April 2009, 11:03 »
Shady i had that prob. The amp would work soemtimes and sometimes it wouldnt, found out that the inline fuse was duff tone of the ends came off and i replaced it and has been fine need to get the box back in now! cant wait  :laugh:
*****MK3 Anniversary*****
*****MK4 GTI T*****
