Author Topic: homemade mk1 golf caddy (4motion 4wd /holset hx40 ,,turbo resto,56k warning  (Read 240719 times)
Offline adaptorman
ill get a better on sorted ,,, guys ,,,that was a test idea see the cammra works llll :grin:
Offline GOLF_STU
  • THE_GIT
awesome  :cool: :cool: :cool:
V TEC KICKED IN Y'ALL!!!
Offline MrBounce
  • Bora TDi 130 Highline - usually filthy.
Stupidly quick - love it!  :laugh:
Keeping schtum. Mostly.
Offline adaptorman
na just fun really ,,
no probs well after more tunieing ive burnt the clutch out so a more updates to come im affraid as clutchers dont like 8/15/21psi of boost going thew them so going for a 5 paddle cermic clutch next ,, see how that performs lll
Offline monzablue16v
You've done all that and I haven't even got my 20v through an MOT :grin: Awesome project adaptorman :)
Offline adaptorman
local lad cool ,, :grin:no point im waiting/thinking and doing a bit ,just hit head on ,,, job gets done a lot quicker ,, lol well it works for me ,,,unsure about you ,,
Offline adaptorman
update , stock dual mass/clutch buggard  holds 8psi on stock dual mass,then turning boost up to 15/17psi the dual mass is buggard and friction plate slipping, so replaced the stock dual mass with a solid steel singal mass and bought a 5 paddle type clutch instead reckon i get a 40percent increase in holding power (so the clutch guy states after the run in period )
how true this is time will tell ,
 , decied to go for a 5 paddle clutch instead of the 3 paddle  type as it will be a bit less graby and ok for road use few pics
more engine gearbox stripping again lol
Offline Steve_PD
bet you could do it with your eyes closed now :grin:
Offline adaptorman
yearh make things simple then they come back out simple lol
also noticed ive been havin a few intake air problems as the intake temps have been reading wrong , causeing hold back , this was due to when i sent some settings to the ecu via easytherm there wernt the correct values , so nicely alterd them as well and aded another sensor
Offline adaptorman
little update , due to a forium pulling my front brake idea down (when it was a stock calipare carrier , ive decided to update them
so here goes
got a pair of 4pot wilwoods
stock calipar pic
tempory fit of the wilwood
first thought all seems ok as i was told these had 330mm discs
as mine are only 312mm and the discs are too big for these calipars, as these came from a volvo 850r
so the next size i can only get is 286mm discs which ill try tomorrow
as the outers fit nice and makeing the adaptors isnt a big problem
plus these wilwoods just catch my 17inch alloys but will smaller discs they will miss ,
what do u guys reckon i should do ,(alway good to have some advise)
