Author Topic: homemade mk1 golf caddy (4motion 4wd /holset hx40 ,,turbo resto,56k warning  (Read 240784 times)
Offline monzablue16v
Clutch looks sweet :) had a 3 puck one on my mini and it was like a switch, awful around town. 5 paddle looks interesting, have to let us know how you get on  :)Upgrading to 4 pot callipers should offset the difference in brake disc size and will make life easier all round :afro: where abouts are you adaptorman if I'm local?
Offline adaptorman
reason i went for a 5 paddle not as ferce as a 3 paddle plate , havin to wait for some smaller 288mm discs so i can adapt these calipars to pipe them up, nr doncaster so not to far away
 im after a pair of left and right hand therds bar any idea who sells it
BAPP bolts in brighouse do threaded bar not sure if they do both ways threaded though. Would imagine Dixon Hall in Wakefield or similar will have it or be able to get it in :)
Offline adaptorman
tryed bap bolts in roth and they dont sell to way therds grr , some bugger must sell it ,,
Ah so one half left thread and one side right thread. hmm try these guys they did me some titanium stuff for the boat a while back :)
http://www.threadedbar.co.uk/
Offline adaptorman
nice one pal... ill give them a buzz 2moz , but good if they can sort it , as i could just normal threded bar , but a pain to keep removing the bars to turn them , i was also looking at left hand tap and die ,  :grin:, time ive right right size maybe easyer just buying some done ,,,
Offline adaptorman
well im runind 288 as the wilwoods just clear due to alloys
so went out testing , all i can say is why didnt i fit these first off , dosent have a problem locking the wheels , and ive also use a t in the rear brakes removed the conpansator valves ,and adjusted the servo up which helps loads
managed to get a couple of updates nothing great thow
first made adaptors and made sure everthing algines up on the calipars
also made so i can remove them to go back to stock use too
then quick rub down andgave door some spray , (was fed up of looking at a blue door
then rubbed it down to add to rough affect lol
next , i wanted more rear wheel camber so added a bit
quick ruber over rear window with buffer
moved wiper so stops in centre maybe a daft idea but works lol
other then this this seem to be runing fine
gave them som proper hard braking , no problems yet
Offline adaptorman
will guys new clutch is bedding in , nicely no slip at 20psi ,, tuck my mate in for \a spin ,thought he was going to pass out lol
Offline Baylez8v
id pass out if i drew up next to that ^^^^^ at the lights, talk about a sleeper....
Offline Asbo Sovfinger
  • I drink your milkshake!!
Q: Well Bond, I know it's not the Aston Martin, but S.M.E.R.S.H will not be expecting this.
'06 Ford Mondeo ST TDCi estate - Machine Silver with full leather Recaro interior (Black)
