Author Topic: homemade mk1 golf caddy (4motion 4wd /holset hx40 ,,turbo resto,56k warning  (Read 240770 times)
Offline adaptorman
thanks guys , its nothing that good its full of rusty /and dints lol ,pop some dates up of shows if there not a million miles away ill have a drive ,,
cheers on the look out for a reasonable camrecorder ,, guys any model numbers spec etc ,, as this one i have is past its sell my date lol
ps went on some test runs 2day , and all has gone well ,,, i decided to leave it at 8psi until ive a few things sorted first lol , but i have tryed it at 15psi ,, was a right buzz been dragged up the road lmao
Offline kcw
What kinda RPM were you seeing full boost by then? 3500?
I told you that clutch wouldnt last! lol
Offline adaptorman
hi pal clutch is fine just needed bedding in , and holding fine a 15psi  im seeing 1 psi at 2500/10psi3500/1500psi at 4200
Offline kcw
Must be mad even with the 8psi never mind 15!
How much you want for the hx35 with the 18cm housing? pm me if you want I couldn't figure out how.
Ken
Offline adaptorman
Ken
it is ought to see it now lol
(the hx35 is a brand new core ,with a lighty used hotside houseing 350
we have just been doing a bit of tuning turned boost upto 19psi tapering down to 17psi with conservative timing afrs 11.5  and the injector duty is around 80 percent
so a calculated guess bhp to be around 380hp at moment and the stock clutch has a slight slip now and again under hard load
 also try this at light was colder air temps and im hitting 20psi at 11.5 afr ,so shes holding well, its dam mental lol
Offline adaptorman
fitted fuel pressure too
not mutch but a bit of test footage , dam mic isnt very good dam breaks up so u carnt hear turbo spool and dump valve grr
http://tinypic.com/r/11ae9z7/4
Offline Khare
  • The bear that khares
dam that thing is quick!!!
Offline Asbo Sovfinger
  • I drink your milkshake!!
Sh!t the bed.        :cool:
'06 Ford Mondeo ST TDCi estate - Machine Silver with full leather Recaro interior (Black)
Offline Andy-H
 :cool: :cool: :cool: :cool: :cool: as Fcuk!!
'02 A4 Quattro sport - gone
'91 Tornado red Mk2
Offline adaptorman
its sh!te vid tbh , as i was just testing , so ill get a mate down to get some outside footage , u should all hear the dam thing then lol
