Author Topic: homemade mk1 golf caddy (4motion 4wd /holset hx40 ,,turbo resto,56k warning  (Read 240757 times)
Offline adaptorman
nice one guys it dose susprize a fair little turbos out there lol , but i supose u dont really see many 4wd caddys with a homemade v6 t sat in either lol
Offline adaptorman
need more bhp and flow so another update
another update on its way , , bigger injectors
now ive to do more modifying to get them to fit in the r32 clyinder head which isnt far off ready for fitting ,
headspacer made,head bolts sorted, exhaust manifold sorted
buggar they dont fit ,, time to adapt them
did the top three first
job done
 next short runner to make
Offline topher
  • Administrator
  • fully functioning
you better be bringing this to gti festival at santa pod next spring! :grin:
high 11s low 12s on the 1/4 mile you reckon?
Offline adaptorman
if ive not givern up on it ,and made another project by then ,,lol ,, i know my bug runs 12.6 300bhp/1.2bar of boost
so with this having better trackion another 100hp power i may get a better time , 12.5/ 11.5 be nice , ..
Offline adaptorman
so thought might as well get some updates and picture damage lol and get it all riped back out ..
flywheel all good
strip down pics
found the problem (afterwoulds the dam rear fueling was too learn in boost ),,all a learning curve so not to worry as i assumed 11.5 in boost was rich enoegh
nige_s
You're mental
Offline adaptorman
You're mental
lol really whys that nige ,,, only a engine ,,, be all built back up ,, soon as i grab a bit of free time ,, as i want to get it boosting again for the dyno lol
Offline Khare
  • The bear that khares
Keep up the good work dude!
Offline adaptorman
cheers pal ,,
so quick bore sand
sump cleaned
 modifyed head bolts lol
longer on the r32
,bingo engine rebuilt
 quick re wire of the new injectors and plugs
 modifyed a few bits and bingo another engine
ill get gearbox and turbo bolted back on ,, and change the steering rack then refit the buggar
« Last Edit: 06 November 2009, 20:06 by adaptorman »
Offline Khare
You seem to be rebuilding engines and gearboxes on a daily basis, do you have a social life?? Is your routine work>car>sleep>work>car>sleep>work>car>sleep?  :grin: :grin:
:afro:
