Author Topic: homemade mk1 golf caddy (4motion 4wd /holset hx40 ,,turbo resto,56k warning  (Read 240800 times)
Offline adaptorman
your ingenuity does make me giggle, proper old skool boffin
are you related to barnes wallis and do you have a beard? [ boffins = beards  :shocked: ]
lol cheers only 38 and no beard lmao ,, just a quick idea ,,,and i needed one ,,,
Offline Khare
  • The bear that khares
Seriously dude you are a genius! You know how to make something from nothing. You should go to scrapheap challenge, you would be seriously awesome mate!
Offline adaptorman
ive tryed to entre but didnt know enoegh poeple to entre ,, id doit been rite laugh , id like to build somert to fly lmao , if possible ,,
Offline Khare
Seriously, find 2 mates to enter because it would be so much fun seeing you there!
Offline adaptorman
right been having a few problems with my engine nothing too bad yet lol , , but noticed a rattle/ camshaft/hydrolic noise which was makeing the engine miss/run rough as its seems to get louder)  from the clyinder head as its been doing this for a while, so after doing a compression test found no2 clyinder was down on compression , i thought the worst , ie , bent valve, piston issuse , , so , after removeing lifters,and checking camshafts ,which were fine , i added some of this
added to the oil and fired it up , with in 5mins of idioling the noise has gone sounds loads better and the engine isnt missing and back up on compression ,,
next , ive had a bit of a boost leak so made a quick boost tester and added a few psi of air , found a small leak on the ecu vacum pipe so repaired it , dam engine pulls now ,,
did a small mobile video , sounds lots better
rather chuffed
http://tinypic.com/r/23kdamd/6
Offline GOLF_STU
  • THE_GIT
any updates?  :smiley:
V TEC KICKED IN Y'ALL!!!
Offline adaptorman
at really  as its basicly done and runing tbh , only thing ive uped the boost and map tunie to 27psi ,, :grin: everything is holding well , hopefully ill get the dyno on the go after the new year ,,
Offline GOLF_STU
  • THE_GIT
you wouldn't be interested in bringing it to the r tech meet on the 10th then?  :wink:
Offline adaptorman
depending on how far away it is maybe , as running costs are a bit extreme lol
Offline Dan34
  • VTEC Powerzzzz
Its in Hinckley in leicestershire  :smiley:
