Author Topic: starting problems AGAIN  (Read 2277 times)
Offline sidecarphil
« on: 09 December 2008, 13:38 »
ok so my golf GTi 8v digi si playing up again
when i start cold it is perfect but as soon as the coolent temps rise the engine start's run's for a few seconds then misses a few times (as if the engine is running out of fuel ) then stop's
if i rev the engine it coughs and misses more till it eventually stop's
as soon as it stop's no fuel pump can be heard , but if i turn the ignition off then on again the fuel pump primes and the engine will start again but the whole cycle start's again !!!
i have replaced all the usuall suspect's with GENUINE VW item's including cam belt , dissy cap and rotor arm , plug leads and plug's , coil , oil and filter , fuel filter , airfilter , blue temp sensor
i also replaced due to a bad earth frying it the ECU for the engine
am i correct in saying there is 2 fuel pump's on these cars ??? if so which does wat ?? is there one that primes and one that run's normally ??
L
if i cant fix this problem i WILL have to sell the car  :cry: :cry: as i need a reliable car for work
PLEASE HELP
Offline sidecarphil
Re: starting problems AGAIN
« Reply #1 on: 09 December 2008, 13:39 »
Also i have done the Digi set up guide  :undecided: :undecided: :undecided:
« Reply #2 on: 09 December 2008, 13:41 »
1st step, disconnec the plug from the main pump under the car, turn key 1 click.  you should hear the in-tank pump prime, if not its bust, and it needs another, or the wiring to it is bust.
next step, when it starts doing it, get under the car and listen/feel the main pump.  If the pump stops before the car cuts out, this is the problem!  In this case, a new fuel pump relay is #1 on the list if that doesnt help either the ecu earth feed is suspect or the wiring to the under-car pumps.
Edit: Or the main pump itself, this would be the case if you heard the in-tank pump running after the main pump stopped as they both are powered by the same wire.
Offline sidecarphil
« Reply #3 on: 09 December 2008, 14:14 »
thank you as always rubjonny
ok i will be checking on saturday when i'm not working and can use the ramp at work  :smiley: :smiley:
any thing else to check ??
Offline richard s
« Reply #4 on: 09 December 2008, 19:35 »
long shot but see if the pinch bolt on the dizzy is tight i had mine come loose and for a week or so it was ok and then all of a sudden it started running like a bag of sh!t and then it wasnt to bad then all of a sudden it wouldnt pull when i set off
Offline sidecarphil
« Reply #5 on: 13 December 2008, 17:22 »
ok now i am p155ed with this dam car !!!!!!
it wont run at all now when it is warm it just very *friendly* personters for a while and stop's all the time , if i keep my foot in it splutters and comes back for about 30 seconds then starts spluttering again
if i turn the ignition off and on again it will run for about a minuite then spluttering a stop's
i chacked both fuel pump's and they are both ok even when it start's spluttering
the dissy is tight and moving it makes no differance to this problem
checked the feed and switch at the coil and feed is 12v and th switch is still switching when till the engine stop's
help please or i'm scrapping it !!!!!!
Offline Khare
  • The bear that khares
« Reply #6 on: 13 December 2008, 17:58 »
you sure you dont have any major air leaks in the vacum system?
Offline sidecarphil
« Reply #7 on: 13 December 2008, 18:02 »
yep they are all checked from end to end  :undecided:
Offline Khare
« Reply #8 on: 13 December 2008, 18:05 »
try and get hold of another ECU, might be your one, maybe its corrupted or something.
Offline sidecarphil
« Reply #9 on: 13 December 2008, 18:16 »
it is a new one from america
i have a problem borrowing one as my car has a CAT so not all of them fit and CAT fitted cars are more rare then non CAT
i was wondering if it was that , think i will try a coil and a ignition amp , think some thing is loosing it's ing feed
