Author Topic: starting problems AGAIN  (Read 2278 times)
Offline sidecarphil
Re: starting problems AGAIN
« Reply #10 on: 14 December 2008, 09:12 »
ok now i am convinced there is something hot and cutting out
i started the car this morning and it is 0 degrees out side , started really well , warmed up to oil temp 54 then started spluttering coughing
i think something like the coil is cutting out , cooling down and working again
is this something any one else has had ??
thanks again Phil
Offline mattkh
« Reply #11 on: 14 December 2008, 09:46 »
HI
Does the coil get hot ?
Tighten all the spade connectors on the coil terminals.
Offline sidecarphil
« Reply #12 on: 14 December 2008, 12:15 »
spades are tight i did a pin drag test on all elec connectors
coil not getting overly hot no
neither is the ign amp
 :undecided: :undecided: :undecided:
Offline sidecarphil
« Reply #13 on: 14 December 2008, 15:13 »
ok i looked at the lambda probe and the wires on the connector, one was out of the connector , plugged it back in but not fixed !!!
so maybe the lambda is broken
Offline danny_p
« Reply #14 on: 14 December 2008, 16:40 »
it's rare but the TCI can play up   normaly when the heatsink has corroded behind it. there cheep enough  to replace to see if it has any effect.
dose the car cut dead or struggel and chough then give up ?
all the VW's have gone bar 1.
Offline sidecarphil
« Reply #15 on: 14 December 2008, 18:52 »
TCI ????
cough's splutters and gives up after 30 second's but restart's perfectly
have been told the lambda heater stay's on for 30 sec's then the probe takes over measuring the co level , so i was pointed in the lamdba probe direction
Offline danny_p
« Reply #16 on: 14 December 2008, 19:12 »
ok  not that then
unplug the lambda and see what happens.  if it ain't there at all it should run fine   just uses default map setting like a normal digi 2 car
Offline sidecarphil
« Reply #17 on: 14 December 2008, 19:59 »
tried that it sort of cleared but it was coughing and spluttering still
i have got a spare in a 4 branch mainfold i bought from a guy i work with so i will try that tommorrow
Offline sidecarphil
« Reply #18 on: 18 December 2008, 11:51 »
ok boy's i think i have fixed it  :evil:
the connector to the ecu was green with corrosion and the lambda probe was fooba'd
fitted my 4 branch manifold yesterday with a new lambda probe in it and the car goes loads better
thanks for the help and advice  :smiley: :smiley:
