Author Topic: Got my W8 this morning...  (Read 7318 times)
Offline big_el
Re: Got my W8 this morning...
« Reply #10 on: 29 November 2008, 21:48 »
yep as the first fuse to go is the one that controls the central locking, windows and interior lights!
yeah i know, ive had that problem in the past, in the pitch black and my window was stuck open. got i sorted in the end though lol
Always a good idea to disconnect the battery when working on electrics  :wink:
yeah suppose so, common sense really  :laugh:
Offline richw911
« Reply #11 on: 29 November 2008, 21:50 »
Old plug end               New plug end
3                                4
2                                5
1                                3
                                  1 (wire runs down to fuse box for + feed)
The ends on the wires you have labelled 3 4 and 5 look like they will slot straight into your standard plug so just use the diagram above. Rhyso is right, the bullet ended wire will be the one needed to run down the A pillar to the grey/blue wire off the back of the dimmer switch to give the illumination (and dimmer controlled)
Give me a shout if you need any help on this as I used to make and sell the adaptors  :smiley:
Wazzr i really think you should start making those looms again, they're only available of Kufatec for £22ish!
Tim
Yeah wazzzer  i would have brought the w8 loom and bora loom from you too!  :wink:
I think you will find he is too busy to make them now tim  :cry:
Offline T_J_G
« Reply #12 on: 29 November 2008, 21:53 »
That's annoying;)
I want the light but can't be bothered to pay £22 for the loom, unless i ordered bulk of them (shippage stay same) and flogged em on for a small profit.
Really don't trust myself with wiring!
Offline Rhyso
« Reply #13 on: 29 November 2008, 21:56 »
That's annoying;)
its really simple - the hardest part is soldering the power cable into the headlight switch  :smiley:
i'm useless with electrics and soldering and i manged to do it  :smiley:
Offline T_J_G
« Reply #14 on: 29 November 2008, 21:56 »
Is there another method other than soldering?
Offline big_el
« Reply #15 on: 29 November 2008, 21:58 »
is soldering better then those clip things, its just i dont have any soldering kit..
Offline richw911
« Reply #16 on: 29 November 2008, 21:59 »
That's annoying;)
Yeah the W8 loom is really easy TBH  :wink:
Offline Rhyso
« Reply #17 on: 29 November 2008, 22:00 »
you can use a scotch lock  :smiley:
Offline Steve_PD
« Reply #18 on: 29 November 2008, 22:00 »
I fancy one of these sometime in the future.
Offline Rhyso
« Reply #19 on: 29 November 2008, 22:02 »
i hear the sound of a clicking mouse buying one from VW Speed as i type........  :laugh: :laugh: :laugh:
well worth it and along with the Bora Vents really add to the interior  :cool:
