Author Topic: Got my W8 this morning...  (Read 7283 times)
Offline big_el
« on: 29 November 2008, 15:46 »
Got my W8 light this morning in the post and this is what came with it
i have read through ALL of the install guides, but i really dont know where to go from here.
im assuming that the black cable i got is to plug the light in the headlining.
so do i now need the cable that runs from the headlining to the light switch ? and where does it plug into at the top because i think you break it into a purple cable on the light switch ?
Offline richw911
Re: Got my W8 this morning...
« Reply #1 on: 29 November 2008, 16:25 »
I know you said you have read all the guides but i used this one and just made up the adpter plug using genuine parts - then its plug and play  :wink:
http://uk-mkivs.net/forums/p/112187/765701.aspx#765701
Offline Rhyso
« Reply #2 on: 29 November 2008, 16:27 »
looking at it, the one with the red bullet connector appears to be the power lead - extend this down to behind the light switch and tap into the blue/grey wire as that will then dim the LED's along with the rest of the dash lights :afro:
Offline big_el
« Reply #3 on: 29 November 2008, 16:42 »
do you know what cable i use ? or where i get it from ?
so if i cut off the metal 'bullet' bit connect the end of a cable and take it down to the light switch and the connect it to the grey/blue cable.
finally going to have a go at doing something myself  :grin:
Offline Rhyso
« Reply #4 on: 29 November 2008, 16:56 »
think i used some 10-15amp cable from halfords - they sell it in 2m rolls i think  :undecided:
you could mate it with the corresponding connector and then take it down rather than trying to solder the connection
Offline Wazzzer
  • Moderator
  • Golf GTI 1.8T AGU
« Reply #5 on: 29 November 2008, 20:12 »
Old plug end               New plug end
3                                4
2                                5
1                                3
                                  1 (wire runs down to fuse box for + feed)
The ends on the wires you have labelled 3 4 and 5 look like they will slot straight into your standard plug so just use the diagram above. Rhyso is right, the bullet ended wire will be the one needed to run down the A pillar to the grey/blue wire off the back of the dimmer switch to give the illumination (and dimmer controlled)
Give me a shout if you need any help on this as I used to make and sell the adaptors  :smiley:
« Last Edit: 29 November 2008, 20:15 by Wazzzer »
Offline big_el
« Reply #6 on: 29 November 2008, 21:40 »
ok, nice one guys, thanks for the help  :wink:
do i need to disconnect the battery or anything? especially when i am 'mating' the two cables together at the light switch.
i was going to PM you Wazzer, because when i was searching, i seen your post about the loom. ill go to halfords tommorow and keep you posted   :smiley:
Offline richw911
« Reply #7 on: 29 November 2008, 21:44 »
Always a good idea to disconnect the battery when working on electrics  :wink:
Offline Rhyso
« Reply #8 on: 29 November 2008, 21:45 »
yep as the first fuse to go is the one that controls the central locking, windows and interior lights!
Offline T_J_G
« Reply #9 on: 29 November 2008, 21:46 »
3                                4
2                                5
1                                3
Wazzr i really think you should start making those looms again, they're only available of Kufatec for £22ish!
Tim
