Author Topic: rear hub nut torque setting??  (Read 8689 times)
Offline richking
« on: 12 November 2008, 18:46 »
hi guys, anyone know the torque setting for the rear centre hub nut on a mk3  gti with disc brakes?
im just about to do my rear wheel bearings and i cant find the correct setting anywhere!
Offline beccasmk3gti
  • golf mk3 gti and a mk3 vr6 182bhp and 223nm
Re: rear hub nut torque setting??
« Reply #1 on: 12 November 2008, 23:13 »
i asked this not so long ago and was told you shouldn't torque the wheel bearings up as this will damage it you should tighten it up until there's no play in the bearing. To do this you need to remove the centre cap in the wheel fit wheel to hub fit castle nut and tighten the nut and wobble the wheel until u feel no play remove wheel and fit the split pin and that's it job done.
Offline Vdubbster
« Reply #2 on: 13 November 2008, 07:19 »
I need to tighten both rears, where can i get new split pins?
« Reply #3 on: 13 November 2008, 07:53 »
Spot on, there is no torque figure, as above tighten untill no play, overtighting them will damage them.
Offline AudiA8Quattro
« Reply #4 on: 13 November 2008, 12:14 »
Rear wheel bearings on mk3's are tapered, so hence no torque setting.
Offline richking
« Reply #5 on: 13 November 2008, 16:04 »
Ok thanks guys, need to replace both rear wheel bearings for the mot (1 was a fail and the other an advisory)
I wondered why i couldnt find the setting in the haynes manual.
nige_s
« Reply #6 on: 13 November 2008, 16:18 »
See you're a Derby lad, you'll be getting your parts from Autovern on London Road then?  Well its called GSF these days, but fat Glynn still runs it.
Offline richking
« Reply #7 on: 14 November 2008, 15:46 »
yeah ive had a few bits from there but there usually isnt much in price to parkway. yeah glynn is still there i dont realy know him though.
« Reply #8 on: 14 November 2008, 20:07 »
you shouldnt need new ones unless u havent got any! motorfactors should have some in!
VW BUSH
« Reply #9 on: 15 November 2008, 21:52 »
Check the bearings, if the cage is intact and the bearings are not worn just adjust them up and check for rumble this is a classic MOT fail get a bit of work out of you trick.
Both mine were an advisory in 06 and the same garage has passed em since.(Car had all new bearings fitted in 05 MOT!)
They are quite loud and obvious when they are gone.
 :wink:
