Author Topic: rear hub nut torque setting??  (Read 8692 times)
Offline bow
Re: rear hub nut torque setting??
« Reply #10 on: 15 November 2008, 22:10 »
hi all i just looked up the rear wheel hub nut torque in my set of vw workshop manuals i acquired when they changed from paper to computer and it said to tighten hand tight then tighten another 20 degrees spin the wheel and then slacken back off to leave a minimal amount of play no more than 5mm over tightening will cause premature failure hope that helps scott.
Offline MrBounce
  • Bora TDi 130 Highline - usually filthy.
« Reply #11 on: 16 November 2008, 00:09 »
I need to tighten both rears, where can i get new split pins?
you shouldnt need new ones unless u havent got any! motorfactors should have some in!
With respect you should always use new split pins. For what they cost, it's a no brainer. It gets messy when split pins fail and nuts come off, followed by hub assemblies...  :rolleyes:
Keeping schtum. Mostly.
