Author Topic: Small screw found in tyre. Should I change it?  (Read 2318 times)
Offline Max Q
« on: 19 October 2008, 16:21 »
Quick one.
I found a small screw in my rear R/H side tyre just now. It was a very small screw, only about 1cm in length and thankfully it had gone through the thick/deepest thread so I don't think it made it far enough in to do any real damage and the tyre hasn't lost any air.
My question is - is the tyre ok or should I just have it changed to be safe? I don't fancy a high speed blow-out on the motorway if the tyre has been weakened or compromised in any way, but it was a tiny screw and I'm pretty sure it hasn't done any real damage.
The tyres are Michelin Pilot Exaltos.
What to do? Cheers.
BTW, I took the screw out in case that wasn't clear..
Mk7.5 R DSG Indium Grey 5Dr
Offline 182_blue
Re: Small screw found in tyre. Should I change it?
« Reply #1 on: 19 October 2008, 16:34 »
have you checked properly for a leak, I.e some fairy liquid and water, it's a hard call really as it's probably fine and I possibly would leave it, but the again for the sake of a hundred quid or so is it worth the risk ?, let's see what others say
Offline tonyh
« Reply #2 on: 19 October 2008, 16:38 »
personally,i would change it  :smiley:
Offline Martz
« Reply #3 on: 19 October 2008, 16:44 »
Quick one.
What to do? Cheers.
The repairs they do these days are exceptionally good. I am a bit funny with tyres and used to change straight away. Personally, as the repairs are good I would get it repaired and spend the money on something nice!
Offline neg
« Reply #4 on: 19 October 2008, 17:06 »
Get it repaired if its gone through - if not dont bother, if it had come out itself you wouldnt know.
Offline JoeGTI
« Reply #5 on: 19 October 2008, 17:24 »
If it was the sidewall, I'd say get it replaced. But since its not, and it hasn't even lost air, I reckon you're ok. Perhaps get a local tyre fitter to have a look at it anyway.
Offline Martz
« Reply #6 on: 19 October 2008, 17:28 »
Absolutley! That goes without saying, I think if it is within half inch of the edges your ok(tyre shop would confirm)
Offline RedRobin
« Reply #7 on: 19 October 2008, 18:06 »
I had the same happen a while ago - Got it repaired with a plug - Not worth risking.
Offline mrlapou
  • Mean GTi
« Reply #8 on: 20 October 2008, 09:24 »
Considering a new tyre has about 8mm tread, this would leave very much less thickness on a worn tyre.
Play safe have it plugged. Only costs about a tenner to do.
Offline Max Q
« Reply #9 on: 20 October 2008, 12:49 »
Thanks for the replies. I think I'll drop it up to my local tyre place and let them take a look to be safe.
