Author Topic: Noisey brakes  (Read 4688 times)
NewGolf
Re: Noisey brakes
« Reply #10 on: 07 October 2008, 20:16 »
Mine make the noise most of the time, but you just notice it more in the morning as its slow in the traffic. No rust on my disks.
Offline 182_blue
Re: Noisey brakes
« Reply #11 on: 07 October 2008, 20:19 »
similar to me really, heavy slow traffic to and back
Offline Top Cat
Re: Noisey brakes
« Reply #12 on: 07 October 2008, 20:22 »
Did not TT do a thread on checking hand brake adjustment IE slightly on all time.  :smiley:
Offline Teutonic_Tamer
Re: Noisey brakes
« Reply #13 on: 07 October 2008, 20:23 »
It was on the way home tonight, no rust build up on the disc that I can see
perhaps its just me , or the fact the brakes are getting damp therefore rusting a bit but i have noticed that there a little noisey when coming to a stop, nothing bad, a bit like my grooved AP discs were (which you expect a little), anyone else get this, or are my ears super sensitive
Is this just first thing in the morning?  And have you noticed a rust build up on the surface of the disc?
Or are they making the noise all the time?
OK, sounds like the pads are partially seizing in the caliper slides.  Quite common in the winter/damper months.
Tomorrow, look at the calipers - through the wheels, and have a close look at the "hammer heads" of the brake pads.  If they look dry, then the calipers probably just need stripping, the pad guides need cleaning and de-rusting, and a thin smear of anti-seize paste - such as copaslip.  That should quieten them down.
Post a close up pic if you arn't sure.
HTH  :smiley:
I feel like a homo
NewGolf
Re: Noisey brakes
« Reply #14 on: 07 October 2008, 20:23 »
Mines mostly noise from the front TC
Mine also did this even before I painted my disks, which I fully stripped and copaslipped up when putting back together. Its a grinding type noise when slowing, its not noticable at any speed over say 20mph.
« Last Edit: 07 October 2008, 20:26 by NewGolf »
Re: Noisey brakes
« Reply #15 on: 07 October 2008, 20:24 »
I did - but you need to ask JV for it.  He lost it when the forum crashed!  :tongue:  :rolleyes:
I feel like a homo
Offline SteveS
  • GTI ED30
Re: Noisey brakes
« Reply #16 on: 08 October 2008, 10:49 »
mine do this too, but all the time. really annoying
SteveS
ED30: Carbonio Intake & Filter | Blueflame TBE | Ebach Sportlines | Neuspeed Torque Arm Insert | Forge DV | REVO Stage2 [353BHP/360lb/ft]
Offline MAT ed30
Re: Noisey brakes
« Reply #17 on: 08 October 2008, 11:33 »
mine did make this noise and after i had took the wheels off to have a look there was a small stone trapped inbetween the caliper and the pad  :shocked:, i also had it happen again and thats was down to a small crack in a pad  :shocked:(track day)
EDITION 30 NUMBER:- 1038 ,Forge dv,ecs dog bone insert,Tints,inpro smoked indicators,panel filter,Black badge,Black roof,Black wing mirrors,REVO stage 2,Blueflame TBE,neuspeed arb,Neuspeed drop links,KW V3,S3 Intercooler,VWR clutch and LSD,VWR 6 pot brakes,1956 vw beetle (2332cc)
Re: Noisey brakes
« Reply #18 on: 08 October 2008, 15:35 »
Get your calipers stripped, cleaned and a fresh coat of anti-seize paste.  Not only does it make them much quieter, but it will marginally improve their efficiency, and help prevent mis-matched wear.
Front and rears should really both be done once a year for normal road use.  Sadly, the stealers will only look with a mirror and torch when the car is serviced.  One of the many benefits of having an independent to do things like that.
I feel like a homo
Offline MAT ed30
Re: Noisey brakes
« Reply #19 on: 08 October 2008, 15:42 »
all true TT i check mine every 6 months, wheels off and a clean up.
dont just think a dealer will check as i have worked for a few :rolleyes: have a look yourself
