Author Topic: Noisey brakes  (Read 4691 times)
Offline Teutonic_Tamer
Re: Noisey brakes
« Reply #20 on: 08 October 2008, 15:50 »
Mines mostly noise from the front TC
Mine also did this even before I painted my disks, which I fully stripped and copaslipped up when putting back together. Its a grinding type noise when slowing, its not noticable at any speed over say 20mph.
Copper-based anti-sieze compounds are OK, but nickel-based compounds are far better.  Much more stable, and less abrasive than copper.  I personally use Bostick-Findley Never-Seez - Pure Nickel Special NSN-165 - it aint cheap, but it is superb, and is good enough for Nuclear power stations!  :tongue:  www.Cromwell.co.uk sell it, but I can't find it online.  Page 1364 of their 2008 catalogue, item code: NS-165, £28.62 +vat.
I feel like a homo
Offline Hurdy
Re: Noisey brakes
« Reply #21 on: 08 October 2008, 19:44 »
When I use my brakes they always make a noise!
zzzzzzzzzzzzzzzzzzzzzzzzzz.zzzzz..zzz.zzz..zz...zz...z
You may have guessed that they are grooved :rolleyes:
Seriously though, even though Awesome used Corsa+ pads I haven't had and squealing at all :cool:
The standard ones did squeal a little, but that was mainly at low speeds in traffic.
Seat Leon Cupra Black 290 DSG
Offline SteveS
  • GTI ED30
Re: Noisey brakes
« Reply #22 on: 08 October 2008, 21:08 »
not really something a non-machanic can do really isit..?
SteveS
ED30: Carbonio Intake & Filter | Blueflame TBE | Ebach Sportlines | Neuspeed Torque Arm Insert | Forge DV | REVO Stage2 [353BHP/360lb/ft]
neo66
Re: Noisey brakes
« Reply #23 on: 08 October 2008, 21:49 »
Majority of the time when braking slowish mine sound like they've gathered surface rust on them as if they've been siting for a couple of days when it hasn't! Think I will will try some fast Braking.
Re: Noisey brakes
« Reply #24 on: 10 October 2008, 22:04 »
Actually, disc brakes are really easy to work on, especially fronts.  The Haynes manual, whilst being full of mistakes, basically gets the fundamentals correct.
I feel like a homo
Offline stealthwolf
Re: Noisey brakes
« Reply #25 on: 11 October 2008, 18:58 »
I just noticed yesterday that when I pressed the brake pedal (engine off), there was a "whoosh" sound from the brake pedal itself. :huh:
Offline 182_blue
Re: Noisey brakes
« Reply #26 on: 11 October 2008, 19:06 »
normal i think, if you keep pumping it the noise stops and the pedal hardens up
