Author Topic: Noisey brakes  (Read 4683 times)
Offline 182_blue
Noisey brakes
« on: 07 October 2008, 19:12 »
perhaps its just me , or the fact the brakes are getting damp therefore rusting a bit but i have noticed that there a little noisey when coming to a stop, nothing bad, a bit like my grooved AP discs were (which you expect a little), anyone else get this, or are my ears super sensitive
Offline bacillus
Re: Noisey brakes
« Reply #1 on: 07 October 2008, 19:15 »
Is it from the rear only?
Without traction power is nothing!
Offline 182_blue
Re: Noisey brakes
« Reply #2 on: 07 October 2008, 19:19 »
hard to say, im not sure where its from
Offline bacillus
Re: Noisey brakes
« Reply #3 on: 07 October 2008, 19:37 »
I asked as it's not uncommon for some pad glazing to occur leading to a low screech from the rear when slowly coming to a stop.
If it is the case then a few sharp stops from around 70mph without actually coming to a dead stop usually cures it.
Offline 182_blue
Re: Noisey brakes
« Reply #4 on: 07 October 2008, 19:39 »
yeh actually I had it once before and after a hairy break moment on the motorway of went
Thx mate
Offline T88OMM
Re: Noisey brakes
« Reply #5 on: 07 October 2008, 19:40 »
I get this quite a lot. Will be doing some emergency stops from 70 to try and cure it then!  :laugh:
Tom
Candy White ED30 | Carbonio | Turbo-Back Milltek | Autotech Fuel Pump | Stage 2 Custom-Code Remap
Offline stealthwolf
Re: Noisey brakes
« Reply #6 on: 07 October 2008, 19:58 »
Definitely in the morning, when I take the car from the garage and out on to the road, I can hear "scraping" noises coming from the rear brakes as I slow down waiting to turn on to the road. Only happens in the mornings and only when I press on the brakes. No problems by the time I reach work.
NewGolf
Re: Noisey brakes
« Reply #7 on: 07 October 2008, 19:59 »
I have the same, you notice it more in the traffic in the mornings. T_T will have a cure I reckon !
Offline Teutonic_Tamer
Re: Noisey brakes
« Reply #8 on: 07 October 2008, 20:03 »
Is this just first thing in the morning?  And have you noticed a rust build up on the surface of the disc?
Or are they making the noise all the time?
I feel like a homo
Offline 182_blue
Re: Noisey brakes
« Reply #9 on: 07 October 2008, 20:13 »
It was on the way home tonight, no rust build up on the disc that I can see
