Author Topic: Rolling Road Results - data runs on Pg2  (Read 5524 times)
Offline Rhyso
« on: 05 October 2008, 20:46 »
Right after hi-jacking Dai's thread i've split it down
above is the plot of my power run and the one below is a plot of the car before the map
what i'm after is ideas and suggestions as why i'm not pulling peak torque until higher in the rev range
going to do some data logging later on but please throw forward ideas  :smiley:
« Last Edit: 07 October 2008, 19:07 by Rhyso »
Offline dai-cymru
  • 1989 MK2 16V
« Reply #1 on: 05 October 2008, 20:50 »
nights my friend so will have to be weekend  :sad: why are you data logging?
Offline Rhyso
« Reply #2 on: 05 October 2008, 20:51 »
missing power between 1800 and 2600rpm - have a look here to see my graph
http://www.golfgtiforum.co.uk/index.php?topic=39185.230
Offline dai-cymru
  • 1989 MK2 16V
« Reply #3 on: 05 October 2008, 20:56 »
your not missing power to me looks like it's topping out and levveling off. diesels have more low down torque so i think thats right, try ask nick from rtec
Offline Rhyso
« Reply #4 on: 05 October 2008, 20:59 »
i did and he said its got a flat spot  :sad:  apparently all the remap company have done have taken the VW map (complete with flat spot) and just upped the power - gives great results but doen't get rid of any underlying problems
need to determine if its something causing it or there is possibly a problem with the map  :undecided:
Offline dai-cymru
  • 1989 MK2 16V
« Reply #5 on: 05 October 2008, 21:04 »
could be anything, fuel pump injectors air filter, plugs anything really, does it feel flat when driving
Offline Rhyso
« Reply #6 on: 05 October 2008, 21:08 »
not really but it probably explains why i seem to get a second surge at 2600rpm onwards  :undecided:
its more noticeable in 4th, 5th and 6th
Offline dai-cymru
  • 1989 MK2 16V
« Reply #7 on: 06 October 2008, 12:30 »
if you cant really feel it dont worry about it
Offline Rhyso
« Reply #8 on: 06 October 2008, 12:33 »
i can though  :sad: did a few test runs down to work this morning - you can feel it lag and then pull hard again
Offline dai-cymru
  • 1989 MK2 16V
« Reply #9 on: 06 October 2008, 12:34 »
is it turbo lag you can feel?
