Author Topic: Rolling Road Results - data runs on Pg2  (Read 5523 times)
Offline RTechUK
  • R-TECH OFFICE 01455 617233
Re: Rolling Road Results - data runs on Pg2
« Reply #30 on: 07 October 2008, 19:25 »
Not as bad as the run we had today on Ben's AUM, It made 209BHP as it should have done, but the ECU made a nice cut back in the torque due to high intake temps.  Normally the car is smooth as a babies bum.
Looking at the TDI dyno graph on Page one, it looks like the map file is a stronger file with the torque limiters capped in the ecu to keep the power lower, nothing bad just the characteristics of TDI remaps.
can you email me that VAGCOM log?
Nick
 01455 617233
Offline Rhyso
« Reply #31 on: 07 October 2008, 19:33 »
Just sent you an email with the log
as per my email only had 2 chances for full throttle 3rd gear runs - near the beginning and the end
is it deliberately toned down then??  :undecided:
strange as Custom Code quote at least 170bhp for the power output...............
had no response from them on the matter either  :sad:
Offline Rhyso
« Reply #32 on: 07 October 2008, 20:13 »
was the ECU number i posted correct?  :undecided:
Offline RTechUK
« Reply #33 on: 07 October 2008, 21:30 »
Yup thats the one m8.
This is what I get back.
VW Golf TDI 1,9 ASZ 038906019FG 130TDI PD
01-0576-00-02 standard, non-automatic
HW Bosch Number 0281010702 SW 1037362796
Do you what want to know what your factory contains???
Downlopad winols demo from here  >>  http://www.evc.de/en/download/down_winols.asp
The send me an email to remaps@bigbhp.co.uk and I will send you the ori bin file to look at.
Nick
 01455 617233
Offline Rhyso
« Reply #34 on: 07 October 2008, 21:53 »
Nick
wow - thats  :nerd:
is there anything i should be looking for specifically?  did you get my VAG COM log?
Cheers Nick - your help is really appreciated!  :cool:
Offline iMation
  • G SiXtY
« Reply #35 on: 10 October 2008, 10:16 »
Rhys, what blocks did you measure for this data logging?
Think i may need to fettle with my MAF a little
Meh....
Offline Rhyso
« Reply #36 on: 10 October 2008, 12:08 »
on mine is was something like block 2/3 for MAF - intake was block 11 but on petrols i think its block 115
i tried data logging on Dai's 2.0 but very few blocks could be measured  :sad:
@ NIck - did you get a chance to view my VAG COM log?
« Last Edit: 13 October 2008, 16:34 by Rhyso »
Offline Rhyso
« Reply #37 on: 12 October 2008, 14:52 »
okay - just done 4 full throttle runs from 30mph to the redline
seem to get the same results - a drop in MAF and intake pressure but looking at the RPM i would have expect it as the turbo is still spooling
it happens at approx 1700rpm and from then on she pulls above the requested figures  :undecided:
Offline Rhyso
« Reply #38 on: 12 October 2008, 20:30 »
here's a snapshot of the 4 runs
   Engine    MAF    MAF    Spec. .   Actual intake press.
TIME   speed  (specified)(actual)intake press
STAMP    /min    mg/str    mg/str    mbar
191.14   1428   250   553.7   1897.2   1193.4
192.22   1596   850   749.7   2152.2   1766.7
193.3   1806   850   1092.7   2335.8   2562.3
194.38   2016   850   975.1   2427.6   2340
195.46   2226   850   1092.7   2458.2   2550.6
196.54   2415   850   1185.8   2458.2   2527.2
197.59   2625   850   1190.7   2458.2   2468.7
198.57   2793   850   1190.7   2458.2   2515.5
199.62   2961   850   1141.7   2458.2   2468.7
200.7   3150   850   1107.4   2458.2   2468.7
201.78   3297   850   1097.6   2458.2   2480.4
202.86   3444   850   1078   2458.2   2468.7
203.94   3612   850   1073.1   2458.2   2468.7
205.02   3738   850   1058.4   2458.2   2433.6
206.1   3864   850   1043.7   2458.2   2433.6
207.18   3969   850   1029   2437.8   2445.3
208.26   4095   850   1019.2   2417.4   2421.9
209.34   4200   850   994.7   2386.8   2398.5
210.42   4305   850   975.1   2366.4   2363.4
211.5   4389   850   965.3   2315.4   2340
212.56   4473   850   931   2274.6   2281.5
213.66   4557   850   901.6   2233.8   2234.7
214.74   4620   850   886.9   2172.6   2211.3
215.82   4683   850   867.3   2121.6   2176.2
244.93   1596   250   543.9   1050.6   1287
246.01   1596   255   289.1   1091.4   1146.6
247.09   1596   255   245   1101.6   1088.1
248.17   1659   440   401.8   1377   1170
249.25   1806   845   739.9   1795.2   1766.7
250.31   1974   765   837.9   1805.4   1860.3
251.41   1512   250   539   1479   1287
252.49   1638   850   769.3   2193   1825.2
253.57   1869   850   1176   2376.6   2726.1
254.65   2100   850   994.7   2448   2363.4
255.73   2331   850   1151.5   2458.2   2574
256.81   2562   850   1210.3   2458.2   2515.5
257.89   2793   850   1185.8   2458.2   2492.1
258.97   2982   850   1156.4   2458.2   2480.4
260.05   3192   850   1117.2   2458.2   2480.4
261.13   3360   850   1097.6   2458.2   2480.4
262.21   3507   850   1068.2   2458.2   2457
263.29   3654   850   1068.2   2458.2   2457
264.37   3801   850   1048.6   2458.2   2433.6
265.45   3906   850   1038.8   2448   2445.3
266.53   4011   850   1033.9   2437.8   2433.6
267.61   4116   850   1009.4   2417.4   2410.2
268.69   4221   850   984.9   2386.8   2398.5
269.77   4305   850   980   2366.4   2386.8
270.85   4368   850   955.5   2325.6   2351.7
271.93   4431   850   931   2295   2304.9
273.01   4494   850   916.3   2264.4   2281.5
274.09   4536   850   901.6   2244   2246.4
275.17   4578   850   891.8   2213.4   2211.3
276.25   4599   850   867.3   2182.8   2199.6
325.52   1512   255   303.8   1193.4   1158.3
326.6   1533   495   504.7   1356.6   1240.2
327.68   1554   535   534.1   1377   1450.8
328.76   1554   425   416.5   1346.4   1357.2
329.84   1575   545   553.7   1438.2   1439.1
330.92   1575   435   441   1285.2   1404
332   1533   325   323.4   1213.8   1216.8
333.08   1617   375   279.3   1693.2   1158.3
334.16   1890   850   828.1   2213.4   2012.4
335.24   1743   850   1117.2   999.6   2035.8
336.32   1638   850   661.5   2193   1567.8
337.4   1806   850   1019.2   2346   2457
338.48   1995   850   989.8   2427.6   2386.8
339.56   2184   850   1068.2   2458.2   2492.1
340.64   2373   850   1171.1   2458.2   2550.6
341.72   2562   850   1200.5   2458.2   2480.4
342.8   2751   850   1190.7   2458.2   2492.1
343.88   2940   850   1156.4   2458.2   2480.4
344.96   3108   850   1117.2   2458.2   2468.7
346.03   3255   850   1092.7   2458.2   2480.4
347.11   3402   850   1073.1   2458.2   2468.7
348.2   3528   850   1063.3   2458.2   2457
349.27   3654   850   1053.5   2458.2   2457
350.35   3759   850   1033.9   2458.2   2445.3
351.44   3885   850   1033.9   2448   2457
352.52   3990   850   1029   2437.8   2433.6
353.6   4095   850   1004.5   2417.4   2421.9
354.68   4200   850   984.9   2386.8   2410.2
355.76   4305   850   975.1   2366.4   2386.8
356.84   4389   850   955.5   2325.6   2351.7
357.92   4473   850   926.1   2284.8   2293.2
358.99   4557   850   901.6   2244   2234.7
360.07   4620   850   882   2182.8   2199.6
361.15   4683   850   862.4   2131.8   2176.2
362.23   4725   850   847.7   2080.8   2129.4
363.32   4788   850   833   2040   2106
410.72   1407   320   298.9   1213.8   1088.1
411.8   1449   430   411.6   1234.2   1181.7
412.88   1470   370   372.4   1224   1205.1
413.96   1512   355   352.8   1224   1193.4
415.04   1554   340   328.3   1234.2   1181.7
416.12   1596   330   318.5   1234.2   1170
417.19   1638   410   382.2   1326   1228.5
418.29   1743   570   578.2   1550.4   1532.7
419.37   1827   785   862.4   1795.2   2059.2
420.45   1470   250   524.3   2040   1392.3
421.53   1638   850   808.5   2182.8   1895.4
422.6   1869   850   1166.2   2366.4   2691
423.68   2100   850   1019.2   2448   2386.8
424.76   2331   850   1146.6   2458.2   2550.6
425.84   2562   850   1225   2458.2   2515.5
426.92   2793   850   1195.6   2458.2   2480.4
428   3003   850   1151.5   2458.2   2480.4
429.08   3171   850   1122.1   2458.2   2480.4
430.16   3360   850   1097.6   2458.2   2468.7
431.24   3507   850   1078   2458.2   2457
432.32   3654   850   1068.2   2458.2   2457
433.4   3780   850   1048.6   2458.2   2445.3
434.48   3906   850   1043.7   2448   2445.3
435.56   4032   850   1029   2437.8   2421.9
436.64   4116   850   1004.5   2407.2   2421.9
437.7   4221   850   994.7   2386.8   2421.9
438.78   4305   850   980   2366.4   2398.5
439.86   4368   850   955.5   2335.8   2351.7
440.94   4431   850   940.8   2295   2304.9
442.02   4473   850   921.2   2264.4   2258.1
Offline RTechUK
« Reply #39 on: 12 October 2008, 23:04 »
Put them in excel and convert the cvs file to a line graph to make the data easier to chew.   I have you two file un my UBS stick ready to put on the vans PC in the morning.
Nick
 01455 617233
