Author Topic: Switched 12V supply  (Read 3632 times)
Offline Altered Carbon
Switched 12V supply
« on: 12 September 2008, 22:14 »
Hi all,
In the middle of fitting my Parrot MK6100 Bluetooth kit in the Ed30 and was using the excellent guide in the Maintenance section (http://www.golfgtiforum.co.uk/index.php?topic=40928.0) - however, the switched ignition supply source (pin 20 at the back of the heater controls) in this guide is a different coloured wired in mine and doesn't seem to be working properly.
Anyone else used another source for the switched 12v supply the kit needs?
Many thanks!
Edition 30 | Candy White
Offline Teutonic_Tamer
Re: Switched 12V supply
« Reply #1 on: 12 September 2008, 22:17 »
I feel like a homo
Offline SteveP
« Reply #2 on: 13 September 2008, 08:32 »
From other recent posts (and my experience) the two options you have for a switched live are either from the cig light socket or from spare connections in the fuse box.
Offline mrlapou
  • Mean GTi
« Reply #3 on: 13 September 2008, 12:38 »
I used both perm 12v and switched 12v feed from spare fuse positions found in the fuse panel at end of dsahboard.
« Reply #4 on: 13 September 2008, 14:59 »
Thanks for the replies!
Any idea which spare ones you used?
« Reply #5 on: 14 September 2008, 15:50 »
Just to add - managed to find a switched ignition supply at the back of the diagnostic port in the drivers footwell. The one at the rear of the heater control (pin 20) was also a switched supply, but I was happier using the diagnostic port supply instead. Some pics of the Parrot install to follow if anyone is interested!
