How to fit a MK5 GOLF Nokia Car Kit and get your radio to mute, and get your sounds through the car stereo speakers.
ok here goes....
To do this job you will need:
An autoleads interface lead ( 06-116b VW 2003- ) and car phone kit - the one shown here is the Nokia Advanced Hands free Bluetooth Car Kit CK-7W.......
1= Interface, 2= Microphone, 3= Control Unit and remote
Some insulating tape, wire strippers & cutters, torx T20 and T15 drivers and a small flat screwdriver or pick set.
and about 1.5 hours......
PREPARING THE LOOM
Unpackage the loom and find the RADIO (Female) end and look for the BLUE wire that goes to the CAR KIT CONTROL UNIT.
Once found, Cut this wire at the RADIO end and pull it out from its loom.
Tape up the loose wire on the RADIO end of the plug.
FITTING THE MIC
Remove the fuse box cover on the end of the dash
Then remove the plastic bar shown below by pulling on it
Next open the cubby below the main light switch
Remove this by squeezing the sides as show. Pull the box down and outwards.
Next, hold your mic at the top of the A pillar and run the wire from it behind the A pillar trim as shown AND ONLY THIS WAY SO AS TO AVOID PROBLEMS WITH SIDE AIR BAGS PLEASE
Then run the wire to the bottom of the a pillar trim - hide the wire by pulling the rubber back and inserting the mic wire.
At the bottom of the a pillar trim insert the plug end of the mic through the hole as indicated
Then pull it out through the cubbyhole opening. Leave the mic wire there for now.
REMOVING THE RADIO CONSOLE
Look to the top of the console at the air vent ( NOT on non-climate cars simply remove rubber mat and follow below )
Remove the small light sensor at the rear of this vent and unplug it.
Then insert your fingers into this hole and pull upwards to remove.
Once this vent cover has been removed look to the rear to find a screw - remove this.
Then insert your fingers into this panel hole and pull upwards to remove.
Look into the top and you will see 2 more screws, Remove these.
Then pull the upper radio/air vents panel upwards to remove it - this is a little painful!
Next remove the 2 screws shown
Then remove the facia panel by pulling it towards the rear of the car, from the top corners.
Once the front panel is removed there are 8 screws holding the radio and heater controls in place - remove these
Now slide the radio out and place it on top of the dash.
Unplug the main loom by pressing the fastener together and pulling backwards
If you have a cd changer or sound pack etc now it the time to remove the extra plugs from the loom. DO NOT TRY TO REMOVE THE 2 MAIN WIRING BLOCKS only the "clipped" in ones.
HAVE RUN OUT OF SPACE - SEE PART 2
