Author Topic: One for the Leakmasters  (Read 3647 times)
Offline JC
  • Back in the North.
« on: 04 September 2008, 20:21 »
Slick - done the search  :wink:
Checked
  • sunroof drains both sides
  • scuttle panel drains both sides
  • door membraine  - door car dry,  drain holes clear
  • bonnet pull cable
all ok . but me drivers side front footwell is soaked after todays downpours.
its only wet in the middle, BUT i did find the under dash trip foam soaked  where it sits above the clutch pedal  :shocked:
help  :cry:
Offline Organisys
  • Old and Slow...
Re: One for the Leakmasters
« Reply #1 on: 04 September 2008, 20:30 »
missing grommet in the bulkhead?
Offline sidecarphil
« Reply #2 on: 04 September 2008, 20:36 »
windscreen rubber would be my guess :)
or taste it see if it is coolant :) maybe the heater matrix and you have only just noticed  :smiley: :smiley:
Offline JC
« Reply #3 on: 04 September 2008, 20:45 »
car wasnt driven - filled up whilist stationary
cooalnt level is fine. like i said. its come down directly ABOVE the clutch pedal area
Offline sidecarphil
« Reply #4 on: 04 September 2008, 20:46 »
ok just throwing idea's around for ya  :drool: :drool:
Offline Jay
  • balding fat cvnt
« Reply #5 on: 04 September 2008, 21:57 »
Trying to kill Chuff by getting him to put coolant in his gob?  :laugh:
Offline mattneck(Beavis)
  • Bristol's Own (DJ) Beavis ;-)
« Reply #6 on: 05 September 2008, 00:41 »
bulkhead grommets for one.. but if its dcoming directly in form above lift the scuttle. acc and clutch cables go into bushes that are horizontal, as the cable goes directly downwards.
Sig Removed. No Longer Applicable. New Sig? Nah. Not Yet..
Quote
Sharpo says: (16:57:39)
to be honest i dont doubt that half ggti users have a shortcut on their desktop for sharpie's last posts
« Reply #7 on: 05 September 2008, 09:55 »
on mine i noticed a cable and some dirt had formed a 'dam' to the right of the ECU bracket, I've lifted the cable up and secured it, and cleaned out the crud.  this seems to have stopped my leak!  apparently it can also come in from the plate under the ECU bracket, since this is a big hole at the factory with a plate glued on top, worth a look.  Also the top corners either side of the screen where the wings attach are a real bad rust spot, well worth a look!
Offline JC
« Reply #8 on: 05 September 2008, 10:38 »
yeah, mine was crudded up by that cable but water could flow - shall have to lift the ECU out to look underneath
MAtt, cables seems ok, but will grease around them which should just make sure  :wink:
Offline tobz.
« Reply #9 on: 05 September 2008, 10:43 »
I agree with jonny on the blank under the ecu, I used to have a mk2 that leaked like a seive on the drivers side. On investigation I found it to be the sealant that had peeled off round the blanking plate under the ecu. I ran a line of fresh silicone round there and it was sorted, nice easy fix that one.
You got any pics of your dad's split ?
