Author Topic: One for the Leakmasters  (Read 3649 times)
Re: One for the Leakmasters
« Reply #10 on: 05 September 2008, 10:57 »
my plan is when dash comes out to take the ecu & scuttle covers out then lie on the floor looking for daylight  :grin:
Offline JC
  • Back in the North.
« Reply #11 on: 05 September 2008, 12:24 »
well i got a giant fanny pad from work  soaking up the water and a heater in the car to aid drying  :rolleyes:
will pull the ecu later and seal the world  :wink:
Offline Spunky_XR4i_GTi
« Reply #12 on: 07 September 2008, 10:21 »
Hmmmm....I kinda have the same with my mk2, I took the carpet out yesterday and started removing the alarm when the heavens opened and i sat on the floor and saw where it was leaking, kinda, my foot was getting wet below the clutch pedal, and it was running down the door rubber, so i pealed it back and it was leaking from behind the roof lining!!, before that it was leaking on the passanger side where the heater thingy is, where i found a previous owner had put flashing around the fan vent under the bulkhead!!!!
Dry weather car at this rate!!!
Currently Driving
Ford Sierra XR4i 3.2V6 [A444 TGP] [Member XROC]
Volkswagen Golf GTI 1.8 8v [D242 HLJ]
Ford Sierra P100 1.8TD [H816 DBW]
Nissan Primera 2.0i SE [N]
Offline Khare
  • The bear that khares
« Reply #13 on: 07 September 2008, 11:56 »
spunky ive got the 2 exact same leaks. passanger side coming fm the fan housing, and from the clutch pedal too. I greased up where the acc and clutch cable comes through the bulkhead but no good.
Exactly were was it leaking frlom on both sides mate? any chance of pics? its starting to fustrate me now!
Offline bigman_10
« Reply #14 on: 07 September 2008, 12:22 »
if the one from the clutch pedal is as spunky described and traced back to the roof lining, i had this leak and it was where my sunroof drain pipe had disconnected itself from the drain hole? try taking your lining down a bit and see if it leaks? if you've got no sunroof, check all the other places mentioned in this thread?
Offline JC
« Reply #15 on: 08 September 2008, 09:43 »
my sunroof drain works, so i can rule that one out . :smug:
and this is the first time had this, and the car has got wet a lot this year.  :cry: am I glad I gave up biking  :laugh:
Offline Gloves88
« Reply #16 on: 08 September 2008, 11:06 »
I too have heaps of leaks just now...some common ones others I dont have a clue.
Want to rule out the "ecu leak"
If i disconnect the battery can I just unplug and remove the ecu without consequences?  :smiley:
« Reply #17 on: 08 September 2008, 11:30 »
yes :)
Offline systemseiko
« Reply #18 on: 09 September 2008, 00:43 »
sh!te given the weather we are havin it looks like there is going to be a few fast track PHD leak engineers LOL,  i have the same tissue and have got it resolved,  after much searching on forum i completed the usual suspects.
New scuttle tray ( mine was cracked)
Unblocked sunroof drain holes
Used Mastic sealant to seal upper blower cover to bulkhead
Front door membranes and unblocked drian holes on doors
Replaced accelerator cable
Replaced Clutch cable
Replaced both door gutter strips
This was done over a period of time and after my recent respray i still noticed water ingress on both sides especially the drivers side coming from surrounding area of clutch cable.
As i had replaced both roof strips during the respray i needed to match the doors to seal with new strips,  ( i had carpet out and cleaned and was not fitting until i got to the bottom of leaks) any way this required brute force with windows down  and slight pulling on upper door so that the frame was a snug fit to the gutter,  to test i got me son to sit outside with a hose until no water ingress was visible.
Time consumming it was but after a tweak here and there both strips/doors became water tight,  i then noticed a steady pool gathering on drivers front well,  upon inspection of drivers door seal i noticed that in  lower lip mid section were seal conjoins the lip was rotten and not making a complete seal,  after a bit of fabrication from a scrap bit of tin and some pop rivets it was easily retified so that a water tight seal was made.
Again i tested thorougly with a garden hose a high pressure and was pleased with the outcome of 100% water tightness.
Interior refitted etc etc and car driven for a few days until the next monsoon,  this time i had parked my car with the Nearside wheels on the kerb and car at an angle, it rained that night & much to my dismay it also leaked. :sick: :cry: :cry:
I sourced the leak to above the pedal box but was lost as to were it was coming in, i got totally F***ed off at this stage and ripped out scuttle tray, wiper assembley, ECU and all cables,  i then got transparent kitched sealant and a paint brush and covered every visible grommet on the bulkhead, i also used sealant when putting the cables back in,  everything was reassembled and selant left to cure for 24 hours.
Again i got my poor son to blast the front screen and surrounding scuttle tray with a hose for nearly 1 hour
and happily have 0 leaks, nil nought nothing.
I know this is long winded but only 1 members experience of water ingress
If it is a 90 mph per hour wind and you drive your car at 90mph downwind, if you stick your head outside would you feel the wind?
Offline JC
« Reply #19 on: 09 September 2008, 11:11 »
~I have now cured all my leaks.
I stuck The daughters corsa on the drive and the Golf is safely Tucked up all Nice and DRY in the garage  :grin: :laugh:
