Author Topic: Puddle Lights! - Now available - Page 5!!  (Read 14290 times)
Offline Rhyso
Re: Puddle Lights! - Now available - Page 5!!
« Reply #70 on: 13 October 2008, 14:13 »
Any more news mate? I'm keen to see how these look when fitted!
i'm working mate!!
only had 30 minutes for lunch and spent 15 of that having my lunch!!  :grin: :grin:
don't have my camera with me but will take some pics tonight
Offline THiNK
  • Golf MK4 GT TDI 150
« Reply #71 on: 13 October 2008, 14:32 »
you only need to pull the stereo forward to run the cable behind it - no need to disconnect anything  :smiley:
Thats the point I only have about 5cm of movement before the cables disconnect themselves :P
CS
Offline Rhyso
« Reply #72 on: 13 October 2008, 14:33 »
CS
unlucky for you then  :tongue:
Offline gtitdi
« Reply #73 on: 13 October 2008, 15:21 »
CS
It is actually possible to feed the wires in the gap behind the centre console (low down) - stick your arm through from the footwell!
Glad you've got them working Rhys!!  :grin:
Offline gtitdi
« Reply #74 on: 13 October 2008, 15:22 »
CS
It is actually possible to feed the wires in the gap behind the centre console (low down) - stick your arm through from the footwell! - so the radio wouldn't have to be moved
Offline Rhyso
« Reply #75 on: 13 October 2008, 15:25 »
CS
i haven't mate - had to abandon the install - was a bit naive and forgot the door cards had to be removed to feed the wires up to the mirrors unless you know of a crafty trick   :smiley:
also sent you a PM too
nige_s
« Reply #76 on: 13 October 2008, 15:26 »
Don't get me wrong, I like what you've done.  But isn't the location in the wing mirror not the best place, surely the door bottom, closer to the B post would be better.  Therefore when you open the door the light swings out in a larger arc over the area where you will actually place your feet.  So when you exit the car you can see where to put your feet.  The door mirror location will be obstructed by the door?  Try putting your feet on the floor directly below the door mirror.  Just a thought?  That's how it is on my Saab, and the Swedes are supposed to be good at the this ergonomic sh*te.
Offline gtitdi
« Reply #77 on: 13 October 2008, 15:35 »
I see what you mean, but if they were in the bottom of the door then they would only function when the door was open.
When they're in the wing mirrors they can illumunate the floor once you've shut the door and are leaving the car as well as once you've unlocked the car and are approaching it.
I've seen a few Fords and Skodas with them in the wing mirrors
« Last Edit: 13 October 2008, 15:38 by gtitdi »
Offline Ben_1uk
« Reply #78 on: 13 October 2008, 17:20 »
We want pictures, we want pictures :laugh:
Powered by the fuel of satan!
Offline bobbarley
  • I'm kind of a big deal...
« Reply #79 on: 13 October 2008, 18:58 »
Remove the door cards, if it's worth doing, do it properly :)
