Author Topic: Puddle Lights! - Now available - Page 5!!  (Read 14292 times)
Offline Rhyso
Re: Puddle Lights! - Now available - Page 5!!
« Reply #80 on: 13 October 2008, 20:29 »
you're going to have to wait for pictures as sadly its a bigger job than first meets the eye
the unit gtitdi has designed works well but at the moment its currently lighting up the inside of my mirror base as i'm stuck!!
i can't see a way to get the LED#s from the mirror housing into the mirror base  :undecided:
@ Bob - you NEED to remove the door card - how else you going to run the wires?
you need to remove both door cards
the stereo or at least pull it forward
underneath the steering wheel
and the mirrors (unless i'm doing something wrong) but i've found it makes it a lot easier to run the wires
i've managed to hide the unit behind the passenger A Pillar trim by removing the rubber part at the bottom (i'll take a picture in the week to explain)
« Last Edit: 13 October 2008, 20:31 by Rhyso »
Offline bobbarley
  • I'm kind of a big deal...
« Reply #81 on: 13 October 2008, 20:42 »
I know, I said you should remove them.
Offline richw911
« Reply #82 on: 13 October 2008, 20:46 »
But you cant do it unless you do, So you have to  :huh:  :undecided:
Offline bobbarley
« Reply #83 on: 13 October 2008, 20:49 »
He said unless he can find a way of doing them ithout removing the door cards.  I was just saying you should :P
Never mind!!!!!!!!!!
Offline Rhyso
« Reply #84 on: 13 October 2008, 20:50 »
anyway been chatting to Steve (gtitdi) and i know how to progress - need to remove the mirror casing
stay tuned!!
and Bob - i said i forgot that the door cards needed to be removed not that it could be done without removing them  :rolleyes:
Offline richw911
« Reply #85 on: 13 October 2008, 20:51 »
Ah i see said the blind man....  :grin:  :wink:
Offline richw911
« Reply #86 on: 13 October 2008, 20:52 »
stay tuned!!
Good work pics tomorrow night then  :laugh:
Offline Rhyso
« Reply #87 on: 13 October 2008, 20:56 »
stay tuned!!
hopefully yes!!  :grin: :grin:
i reckon the mod will be worthwhile just give yourself plenty of time
biggest problem i've found feeding the wire through the door - as often you need to poke the wires up or down and or through a specific gap which can be tricky
and i'd forgotten what a pain in the arse refitting a door card is  :angry:
Offline bobbarley
« Reply #88 on: 13 October 2008, 20:56 »
Go and fit it now, in the dark...
Offline richw911
« Reply #89 on: 13 October 2008, 20:57 »
stay tuned!!
 :cool: yeah bloody door cards  :angry:
