Author Topic: Just failed MOT  (Read 4260 times)
Offline Nate187
Just failed MOT
« on: 30 July 2008, 11:45 »
My 8v digifant has just failed it MOT
1. Shock absorber leaking
2. Chassis leg has excessive corrosion seriously affecting its strength withing 30cm of the body mountings.
3. (5.8%) exhaust emissions carbon monoxide content excessive.
4. Wheel bearing excessive play.
5. Both front lower suspension arm bushes deteriorated.
6. Brake valve leaking.
7. Both rear brake pipes corroded.
It looks worse than it is, i wanted new shocks and springs all round anyway so that sorts no.1. The chassis leg and lower arm bushes will need doing by the garage. The valve and brake pipes are easy enough to so myself.
But what about the exhaust emissions, How can this be sorted?
Its not a Gti without the stripe
Offline Horney
Re: Just failed MOT
« Reply #1 on: 30 July 2008, 11:47 »
A good tune up via RJ's guide in the MKII section.
nick
Offline Nate187
Re: Just failed MOT
« Reply #2 on: 30 July 2008, 12:30 »
Im waiting for the garage to get back to me with a price. I might not be able to justify fixing it if its too costly as the tax ran out today too.
This could be the end of the GTI  :cry:
sharpie
Re: Just failed MOT
« Reply #3 on: 30 July 2008, 13:08 »
fix it yourself or don't buy such an old car.
Offline Dec
Re: Just failed MOT
« Reply #4 on: 30 July 2008, 14:27 »
 :huh: Bit harsh. What if he had no choice but to get a cheap car?
Offline rowlers
  • I'm back - MK7 GTI
Re: Just failed MOT
« Reply #5 on: 30 July 2008, 18:20 »
mine too :cry: :cry:
rear flexy twisted (has been for how many years???)
2 brake pipes corroded, valve to calipers
steering rack gaitor
number plate bulbs.
Already done the bulbs and gaitor.
Doing brake pipes on sat morning, only prob is, I've no MOT and tax runs out tomorrow and can't renew cos I've no MOT till sat - what do you do eh - fingers crossed I don't get pulled!
Offline Nate187
Re: Just failed MOT
« Reply #6 on: 30 July 2008, 18:50 »
I can do the majority of it myself but dont have the equipment to do welding on the chasis leg, fit the lower arm buses or sort the emissions out. The garage never got back to me today but i may have to seriously consider selling this car cheap or breaking it  :cry: such a shame
sharpie
Re: Just failed MOT
« Reply #7 on: 30 July 2008, 19:49 »
you don't need equipment for wishbone bushes, just buy new wishbones from gsf or eurocarparts with the bushes already pressed in. end of hassle.
there are many newer and cheaper cars i can think of than a mk2 golf.
« Last Edit: 30 July 2008, 19:50 by sharpie »
Offline richard s
Re: Just failed MOT
« Reply #8 on: 31 July 2008, 21:14 »
your looking at about £40 for a tune and last time i bought a bottom arm (it was for a fiesta)but was about £15 as for welding try some different garages as it may not be as bad as the fail sheet makes it sound
also you have to weigh up the cost of replacing car against cost of repairing it
Offline Llewellyn
Re: Just failed MOT
« Reply #9 on: 31 July 2008, 21:34 »
Buy mine off me
with 12 months MOT!!!
http://www.golfgtiforum.co.uk/index.php?topic=87555.0
Mk2 GTI 16v
Mk2 Scirocco 8v
