Author Topic: Just failed MOT  (Read 4265 times)
Offline Nate187
Re: Just failed MOT
« Reply #20 on: 04 August 2008, 18:24 »
I agree, thanks for the reply guys but theres no way im bodging it.
« Last Edit: 04 August 2008, 18:56 by Nate187 »
Its not a Gti without the stripe
Offline nealey
Re: Just failed MOT
« Reply #21 on: 04 August 2008, 18:28 »
That looks very tidy and would be a shame to scrap it
With the brake lines most spares places will make up the copper lines if you take them the old ones to make copies from
Offline uber pikey
Re: Just failed MOT
« Reply #22 on: 04 August 2008, 20:27 »
I will put a spanner in the works but do not be worried by this, the probable reason for your high emissions are the valve syem seals. This is not a very big job and you can do it without removing the head, not expensive(£13aprox), they are a normal fault and common to high emissions.
The welding is just time assuming and not too expensive. If I was close to you then I would come across and help.
I saw it so I took it.
Offline Nate187
Re: Just failed MOT
« Reply #23 on: 04 August 2008, 22:02 »
Oh god not another job!  :angry: :grin: are there any guides/threads to help me with the valve stem seals?
Offline nealey
Re: Just failed MOT
« Reply #24 on: 04 August 2008, 22:25 »
I wouldnt go worrying about valve stem seals just yet, as mentioned before make sure its set up properly first using the guide by rubjonny in the faq
Offline Jay
  • balding fat cvnt
Re: Just failed MOT
« Reply #25 on: 04 August 2008, 22:43 »
Offline Nate187
Re: Just failed MOT
« Reply #26 on: 30 October 2008, 23:27 »
My 8v digifant has just failed it MOT
1. Shock absorber leaking
2. Chassis leg has excessive corrosion seriously affecting its strength withing 30cm of the body mountings.
3. (5.8%) exhaust emissions carbon monoxide content excessive.
4. Wheel bearing excessive play.
5. Both front lower suspension arm bushes deteriorated.
6. Brake valve leaking.
7. Both rear brake pipes corroded.
It looks worse than it is, i wanted new shocks and springs all round anyway so that sorts no.1. The chassis leg and lower arm bushes will need doing by the garage. The valve and brake pipes are easy enough to so myself.
But what about the exhaust emissions, How can this be sorted?
Right ive dug up my old thread to let you guys know how im getting on, its nearly time to put her in for an MOT again, so far ive....
1. Replaced suspension with Boge gas dampers & Eibach springs.
2. Replaced front wishbones and bushes.
3. Replaced front wheel bearing.
4. New rear brembo discs & Pagid pads (i had an advisory on the discs).
5. New vag exhaust system as i didnt like the Scorpion dtm that was fitted.
6. New 10w 40 oil, vag oil filter and coolant.
7. New vag rubber mats :D
9. Resprayed red gti grill stripe ;)
8. Today i finished the timing & Co2 mixture via rubberjohnnys guide (cheers mate ;)), I bought a gasterster and timing light off ebay to do this, also fitted a new rocker gasket and gave the cover a general clean up.
Ive only been round the block but the car seems to run and handle fantastic now. I still need to replace the rigid brake pipes and a new brake bias valve which i have.
Ive also decided to fit new tyres as ALL of them have slow punctures! wtf!
Then the cars ready to go into the garage for the welding on the chasis leg and an MOT :D
When its passed it'll be getting 4 wheel lazer alignment and a damn good clean :D Cannot wait!
Offline bomp
Re: Just failed MOT
« Reply #27 on: 31 October 2008, 01:34 »
Good job man, the rear wheels can't be adjusted for camber or toe because they are just fixed to the rear axle in one positon only, but they can be tapped about a few mm left or right when the plates on the axle to chassis are loosened. But the front ones can be adjusted slightly, so go for a 2 front front wheel alignment, the people doing it should know that MK2 rears can't be done.
I've seen a thin plate (I think it's only nylon or something) that can be bought in America which allows toe & camber for the rear wheels, but its mostly American trackday people that have used them. It fits between the stub axle & axle itself, and it has various wedges of thickness to it, so you turn it around according to the instructions, to apply whatever toe & camber you need.
I love it when I go to the MOT station, because they know they can't bullsh!t me for extra work/money, as they know I fix my own car  :smug:. If it's just the lights need adjusting or CO2 screw to pass, then I'd let them do it to retest it (Well it was the only things to be done to it last year anyways).
But yeah, it's always good sorting your own car out :afro:
Life is like a skid mark on a toilet bowl.  Sooner or later someone\\\'s going to pi$$ you off.
Offline DarnPB
  • Formerly Darnpistonbroke
Re: Just failed MOT
« Reply #28 on: 31 October 2008, 10:14 »
Nice one buddy. Feels good knowing that you have saved another one doesn't it?
Incidently, don't take any notice of stupid comments like the one Sharpie put in. You do what you want to do and comments like that are neither requested or warranted. :wink:
