Author Topic: Mk5 GTI VAGCOM logs  (Read 6504 times)
Offline neg
Mk5 GTI VAGCOM logs
« on: 22 May 2008, 21:26 »
Has anybody got any logs they want to share or would they be willing to do some?
Be useful to do some comparisons thats all - boost, maf etc I will give a list of what to log.
Oh and I may have a spare VAGCOM cable which I will be putting in the classifieds soon.
Offline Rob-MK5
Re: Mk5 GTI VAGCOM logs
« Reply #1 on: 22 May 2008, 21:42 »
Will be doing mine tomorrow just to make sure the dv valve is ok before rolling road,  :wink:
Offline k4ith
« Reply #2 on: 22 May 2008, 22:02 »
I want to do some but dont know how? i have a pdf how to on my pc but have never got round to reading it lol!
MKV Golf GTI Edition30, GIAC Pump&Race Map, AutoTech Fuel Pump, R32 Front Brakes, Dbilas Flo-master Intake, S3 Intercooler.ECS Dog Bone Insert.
MKII GTI 8v Tornado Red 88 - Das Projekt
Offline 182_blue
« Reply #3 on: 22 May 2008, 22:02 »
i must get vag com
Offline neg
« Reply #4 on: 22 May 2008, 22:14 »
Rob, if you wouldnt mind loggin a few bits...
Best bet is a 4th gear run from 2/3krpm upto red line
If you have the USB interface you can put it in 'turbo' mode to get more readings and log blocks 020, 115 and 004
What mods do you have?
Offline neg
« Reply #5 on: 22 May 2008, 22:22 »
Would be usful if you did MAF reading too - just one run on that to see what peak you get.
Out of interest my peak went up 7 when I swapped to the Carbonio.
Edit:  002 will give MAF readings
Offline neg
« Reply #6 on: 22 May 2008, 23:18 »
Offline Rob-MK5
« Reply #7 on: 22 May 2008, 23:32 »
Running Revo and the exhaust,
I dont have Vagcom myself but Emaps guy is over tomorrow so will do some test with him Neg  :wink:
Offline Max Q
« Reply #8 on: 23 May 2008, 01:04 »
Here ya go:
Quote
Engine Speed   Engine Load   Boost Pressure   Boost Pressure
                                       (specified)      (actual)
 rev/min                %                  mbar           mbar
2560                   15                   310            1020
2520                  15.8                  750           1010
2600                    91                  1820           1160
2720                  140.6                 2130          1770
2880                  182.7                 2280          2250
3040                  191.7                 2300          2370
3200                  191.7                 2290          2400
3400                  191.7                 2290          2410
3560                  191.7                 2280          2420
3720                  191.7                 2260          2400
3880                  191.7                 2230          2350
4080                  184.2                 2220          2230
4200                    182                  2210           2170
4360                  182.7                 2210          2160
3480                  190.2                 2180          2300
3560                    182                  2040           2190
3560                   21.1                   340           1340
3560                   15.8                   320           1140
3400                   16.5                   320           1060
3280                   16.5                   320           1040
3160                   16.5                   320           1030
3040                   16.5                   320           1050
2960                   15.8                   320           1050
2840                   16.5                   320           1050
It wouldn't let me attach the CSV file. I can email you the log in CSV format if you want. This obviously isn't a 2k-red line log. I have plenty of red line logs too of you want to see them.
Car is a standard GTi that has been Revo'd, hence the high boost!
« Last Edit: 23 May 2008, 01:20 by Max Q »
Mk7.5 R DSG Indium Grey 5Dr
Offline 182_blue
« Reply #9 on: 23 May 2008, 06:43 »
where did we all get out Vag com ?
