Author Topic: Mk5 GTI VAGCOM logs  (Read 6505 times)
Offline joesgti
Re: Mk5 GTI VAGCOM logs
« Reply #10 on: 23 May 2008, 07:02 »
i dont think im working this out right!! 2420 mbar cannot be 35psi, how would you work out how much psi you are running from mbar???  :huh:
i think a std gti runs about 9psi.
GTI MK5
Not the only GTI...........but the best! ; )
Offline CocoPops
« Reply #11 on: 23 May 2008, 08:44 »
My Vagcom cable should be here next week :)
I bought it direct from RossTech, but had it sent to a US address and then that person is bringing it to the UK next week :D
£198 for the full cable, not just the MicroCan one. They are £269 at the UK supplier.
2018 GTI Performance Pack DSG 5dr, Tornado Red, Leather, 18" Seville Wheels, DCC Suspension, Tints, RVC
2018 Lotus Elise Sport220
Previous : 1983 Mk1 Golf 1.1 & 2008 Mk5 Golf GTI Ed30
Offline Max Q
« Reply #12 on: 23 May 2008, 09:09 »
Boost pressure gauges (like the one you have fitted I think) measure boost above atmospheric pressure as far as I know. So here's the math!:
1 atmosphere = 1013.2 mbar on a standard day.
1 mbar = 0.01451 psi
2420-1013=  1407 mbar x 0.01451 = 20.42 psi
What boost are you running joe?
Mk7.5 R DSG Indium Grey 5Dr
Offline neg
« Reply #13 on: 23 May 2008, 09:56 »
Like Max said you have to take atmospheric pressure into account which is always around 1000 then convert into PSI - which gives you a rough idea to comapre to your boost gauge.
Max - I would be interested in those logs -if you could email them to me  :wink:  Will PM you email address.
Rob, yeh that would be interesting to see yours - is yours of standard flavour or Ed30 ?
Offline Max Q
« Reply #14 on: 23 May 2008, 10:38 »
Done. :cool:
Offline neg
« Reply #15 on: 23 May 2008, 10:55 »
Interesting... looks like I am loosing a couple of PSI throughout the range - which is something I have read about on vortex.
MAF readings anyone?
Offline neg
« Reply #16 on: 23 May 2008, 10:58 »
where did we all get out Vag com ?
I have a Micro-CAN cable for sale if you want to join the fun...
Offline 182_blue
« Reply #17 on: 23 May 2008, 15:40 »
you have pm
Offline Rob-MK5
« Reply #18 on: 23 May 2008, 17:34 »
Help i dont understand any of it,
Does this look ok?
   Group A:   '115            Group B:
      Engine SpeedEngine Load      Boost Pressure   Boost Pressure
   TIME         (specified) (actual)   TIME
Marker   STAMP    /min    %    mbar               mbar   STAMP
   0.02   2120   88.7   790   1320
   0.12   2160   77.4   630   1250
   0.25   2200   48.9   440   1230
   0.38   2200   31.6   450   1180
   0.56   2240   27.8   470   1110
   0.69   2280   27.8   470   1080
   0.81   2280   27.8   460   1060
   0.94   2280   27.8   460   1050
   1.13   2280   27.8   460   1050
   1.25   2320   27.8   460   1040
   1.38   2320   27.8   460   1040
   1.51   2320   28.6   480   1040
   1.69   2360   31.6   540   1030
   1.82   2320   34.6   550   1050
   1.94   2360   35.3   580   1060
   2.07   2360   36.1   600   1070
   2.25   2400   37.6   630   1080
   2.38   2400   38.3   620   1080
   2.5   2400   39.1   630   1090
   2.63   2440   39.1   630   1100
   2.81   2440   39.1   620   1100
   2.94   2480   39.1   620   1110
   3.06   2480   39.1   860   1110
   3.19   2520   57.1   1260   1090
   3.37   2560   82.7   1380   1180
   3.5   2600   92.5   1500   1240
   3.62   2640   94.7   1600   1290
   3.75   2720   101.5   1970   1360
   3.93   2800   121.1   2240   1590
   4.06   2880   138.3   2260   1810
   4.19   2920   150.4   2310   1950
   4.31   3040   160.9   2390   2070
   4.5   3160   172.9   2400   2140
   4.63   3240   175.9   2390   2170
   4.76   3320   177.4   2380   2180
   4.88   3400   176.7   2380   2180
   5.06   3560   176.7   2370   2180
   5.19   3640   175.9   2350   2190
   5.32   3720   176.7   2340   2200
   5.44   3800   178.2   2320   2210
   5.63   3920   175.2   2300   2150
   5.75   4040   173.7   2290   2120
   5.88   4080   169.9   2280   2090
   6   4200   169.2   2270   2070
   6.19   4320   169.2   2250   2030
   6.31   4360   168.4   2210   2040
   6.44   4440   168.4   2170   2020
   6.57   4520   167.7   2150   2020
   6.75   4640   168.4   2120   1980
   6.88   4720   167.7   2100   1970
   7   4800   166.2   2100   1970
   7.12   4880   164.7   2080   1950
   7.31   5000   163.2   2050   1940
   7.44   5040   160.9   2030   1930
   7.56   5120   160.2   2020   1920
   7.69   5200   158.6   2000   1890
   7.87   5280   156.4   1970   1870
   8   5360   155.6   1960   1850
   8.12   5400   154.1   1940   1830
   8.25   5480   151.1   1910   1810
   8.44   5560   151.9   1900   1770
   8.57   5640   149.6   1880   1770
   8.69   5720   148.9   1860   1750
   8.81   5760   147.4   1850   1740
   9   5840   146.6   1830   1720
   9.13   5920   145.9   1810   1710
   9.25   5960   144.4   1790   1700
   9.38   6000   142.9   1780   1680
   9.56   6120   141.4   1750   1660
   9.69   6160   139.8   1740   1650
   9.81   6200   138.3   1730   1640
   9.94   6240   139.1   1720   1620
   10.13   6320   136.8   1710   1610
   10.26   6400   136.1   1700   1610
   10.38   6440   134.6   1680   1610
   10.5   6480   133.8   1670   1610
   10.69   6560   133.1   1660   1590
   10.81   6600   133.1   1640   1590
   10.94   6640   132.3   1630   1590
   11.07   6680   131.6   1610   1580
   11.25   6760   130.1   1600   1570
   11.38   6800   133.1   1380   1560
   11.5   6840   131.6   1250   1570
   11.63   6880   118   1030   1690
   11.81   6760   13.5   300   1620
   11.94   6440   13.5   300   1330
   12.07   6200   16.5   300   1220
Offline joesgti
« Reply #19 on: 23 May 2008, 17:52 »
right so 20.42 psi from a remapped ed30 sounds about right   :smiley:
im running 18psi from an "original  :wink: gti" so im chuffed with that. if i make 260 bhp il be a happy chappy  :smiley: as its plenty enough for a lad my age  :cool: :smiley:
GTI MK5
