Author Topic: Mk5 GTI VAGCOM logs  (Read 6506 times)
Offline neg
Re: Mk5 GTI VAGCOM logs
« Reply #20 on: 23 May 2008, 17:58 »
You'll probably find about 18-20psi from both - but the Ed30 turbo will obviously be giving out more power as its a bigger turbo.
Edit:  Rob you have PM
Offline Rob-MK5
« Reply #21 on: 23 May 2008, 21:46 »
Does mine seem to be running good boost?
Rob
Offline Max Q
« Reply #22 on: 24 May 2008, 00:08 »
i dont think im working this out right!! 2420 mbar cannot be 35psi, how would you work out how much psi you are running from mbar???  :huh:
i think a std gti runs about 9psi.
Boost pressure gauges (like the one you have fitted I think) measure boost above atmospheric pressure as far as I know. So here's the math!:
1 atmosphere = 1013.2 mbar on a standard day.
1 mbar = 0.01451 psi
2420-1013=  1407 mbar x 0.01451 = 20.42 psi
What boost are you running joe?
right so 20.42 psi from a remapped ed30 sounds about right   :smiley:
Mines just a standard GTi with Revo. Not an ed30. :cry:
Mk7.5 R DSG Indium Grey 5Dr
