Author Topic: Tempreture Sensor -NEED HELP PLEASE  (Read 1905 times)
Offline admc6
« on: 22 May 2008, 13:05 »
I have the goot old cutting out problem  :rolleyes:
I have changed pretty much everything now and i'm onto the tempreture sensor.
The car cut out when the revs drop, but only when the car gets warm. I had a look and its about when the oil reaches 60.
Is this tempreture sensor the air intake tempreture sensor or the coolant one?
I hope to order this this afternoon
« Last Edit: 23 May 2008, 17:15 by admc6 »
Offline admc6
Re: Tempreture Sensor
« Reply #1 on: 22 May 2008, 13:29 »
I think its this one;
ECU coolant temp sensor
Does anyone know where its located on an 8v gti?
Offline Rmachines
  • Passat 20vT Estate and Candy White MK3 1.8 GL
« Reply #2 on: 22 May 2008, 14:26 »
Undo the Four pin plug,  Pull out the retaining clip and pop it out,  Take the o-ring out, it somtimes remains in the hole.  Plug the new one in with the 0-ring,  push the clip back in and reconect the cables.
Let us know if it sortes the probelm
10 golfs and counting!
Engine cranes = the ultimate tool to test the tensile strength of Everything you didn't disconnect!
Offline admc6
« Reply #3 on: 22 May 2008, 14:41 »
Cheers for that, i will let you know. I so hope it does sort it out, its doing my head in now.
Dont suppose you know the part number?
Offline Rmachines
« Reply #4 on: 22 May 2008, 14:52 »
part number 357919369F
temperature sender / for coolant temperature gauge / and / electronic control unit
20MM 4 pin black/yellow 'DIGIFANT' 'MONOMOTRONIC
Offline mush
« Reply #5 on: 22 May 2008, 15:07 »
thats one clean head Rmachines  :drool:
MK2 golf 16v :-)
Offline admc6
« Reply #6 on: 22 May 2008, 15:28 »
Thanks for that rmachiones. I will let you all know how i get on
Offline admc6
« Reply #7 on: 22 May 2008, 17:11 »
just been testing the car. started fine, vut outr at the normal 60 oil temp. started straight away, cut out 72. started after a couple of seconds and cut out about 84 on oil temp.
have ordered a sensor £27 from vw so am picking it up in the morning and will fir 2moro night
Wish me luck
Offline Rmachines
« Reply #8 on: 22 May 2008, 17:31 »
cool hope it works for ya.
Quote
thats one clean head Rmachines  drool
Thanks! I spend many happy hours polishing my head  :grin:
Offline admc6
« Reply #9 on: 23 May 2008, 17:14 »
Well no joy  :cry:
The temperature sensor didnt do the trick.
Please Please can someone suggest anything else. I am running out of money and patience now
