Author Topic: Tempreture Sensor -NEED HELP PLEASE  (Read 1908 times)
Offline Rmachines
  • Passat 20vT Estate and Candy White MK3 1.8 GL
Re: Tempreture Sensor -NEED HELP PLEASE
« Reply #10 on: 23 May 2008, 18:19 »
get it on diagnostics!  :wink:
10 golfs and counting!
Engine cranes = the ultimate tool to test the tensile strength of Everything you didn't disconnect!
Offline admc6
« Reply #11 on: 23 May 2008, 18:28 »
Its been on but it doesnt come up with any faults.
I have been out again to check the vacuum hoses for any leak but still cant see anything
Offline admc6
« Reply #12 on: 23 May 2008, 20:24 »
With it cutting out at the same oil temp all the time, does anyone think it could be the oil pressure sensor? I have read it may cause the problem. Although saying that i was looking in my bentley, and if you read it doesnt mention a sensor, only switches
Offline Rmachines
« Reply #13 on: 23 May 2008, 20:28 »
No the Oil pressure sensor is just for the warning lights doesnt effect the ECU.
Offline admc6
« Reply #14 on: 23 May 2008, 20:34 »
I thought so. It was just in the cutting out thread. Just been having a read but no closer to discovering the problem.
Offline DazVR6
  • mk3 VR6...FEEL THE GRUNT.
« Reply #15 on: 23 May 2008, 21:26 »
Engine speed senser, a very common cause of cutting out and it might not register a fault code. Also even if a vac hose looks ok they can become brittle in areas you might not be able to see, i'd just swap them all for silicone stuff, its pretty cheap off the bay.
Maybe you should write out a list of what you've changed/replaced so far so we can narrow it down.
« Last Edit: 23 May 2008, 21:29 by DazVR6 »
Offline admc6
« Reply #16 on: 23 May 2008, 21:31 »
The speed sensor is new (well a year old) and looks ok to me. Will start a new post with  it
