Author Topic: Catalytic coverter faulty!!! ed30  (Read 5694 times)
Phil mcavity
Re: Catalytic coverter faulty!!! ed30
« Reply #10 on: 23 April 2008, 21:27 »
They should just creep, mine at the moment will hill start and roll foward on a steep incline!!!, all other vw's with dsg have not done this , i know somethings wrong, cus she almost stalls when i come to standstill at a junction.
Offline TagnuT
  • Edition 30
« Reply #11 on: 23 April 2008, 21:53 »
Not right there Phil, hope you get it sorted. Has the Lambda probe been damaged on the change over?
Bye Bye Edition 30
Phil mcavity
« Reply #12 on: 24 April 2008, 06:59 »
i think your right tagnut,  one of the sensors is damaged, i know its some kind of sensor fault, because theyve put new software to the cars engine management and its running worse, so to me, thats no an actual blockage of the cat, but a faulty sensor tell the ecu wrong info.
Offline Cass
« Reply #13 on: 24 April 2008, 08:29 »
If they are replacing the cat, make sure they either test/retest the lambda sensors or replace them as well. Diagnostics should have shown up a faulty lambda sensor though.
Cass
Now: VW Touareg Altitude V6 TDI 3.0 240 bhp, Diamond Pearlescent Black
Previous: MY2007 GTI, 3 door, manual, pearlescent black and lots of toys - gone to a good home : )
Offline topher
  • Administrator
  • fully functioning
« Reply #14 on: 24 April 2008, 09:14 »
^ as above, if they're replacing the cat they must be pretty confident that the o2 sensor is sending the right signal.
Offline illyun
« Reply #15 on: 24 April 2008, 13:14 »
Glad to see you're getting it done under warranty Phil... wouldn't have been a nice introduction to Ed30 ownership if you had a big fat repair bill within days.  By the way, I personally wouldn't advertise the fact that it had Milltek on because you never know if someone from the dealer is reading this.   :rolleyes: :evil:
Mk1 GTI Campaign, Mk5 GTI Edition 30, Mk6 GTI (Coming Soon...)
Offline neg
« Reply #16 on: 24 April 2008, 17:52 »
Maybe - I have been in a situation where I had a problem with a previous car, all the insisted on was me returning it to stock to replicate the fault and then they would work on it under warranty ... wierd I know, especially as the problem was not even related to the 'aftermarket' parts.
After all with Milltek ot stock exhaust it shouldnt be doing this anyway.
Phil mcavity
« Reply #17 on: 24 April 2008, 17:55 »
So if you get a full turbo back system,say from milltech, does it come with these same senders or do they have to be removed from the Factory fit Cat?
Offline Hurdy
« Reply #18 on: 24 April 2008, 18:01 »
Good question!
When they put mine on they didn't do any wiring and so I'd presume that the probes are simply slotted into the Milltek unit.
Seat Leon Cupra Black 290 DSG
Offline topher
  • Administrator
  • fully functioning
« Reply #19 on: 24 April 2008, 19:03 »
the milltek cats are designed to be compatible with the stock sensors :afro:
