Author Topic: vaccume hose  (Read 2000 times)
Offline gtiscott
vaccume hose
« on: 22 April 2008, 11:10 »
i am changing all the vac hoses to silicone ones, is it 3mm hose i need?, will 2metres be enough, also where can i get the little clips that hold them on
cheers
Scott
Offline mark3valver
Re: vaccume hose
« Reply #1 on: 22 April 2008, 13:48 »
go on ebay and search 3mm ID vacuum hose - guy sells 3 meters for £12.99 delivered I think.
You don't need the connectors they just push on tight, 2 meters would do it, the longest goes up to the ECU, I can show you a pic if needed
want a pair of raceland buckets with model specific subframes for £150 delivered? go here
http://www.golfgtiforum.co.uk/index.php?topic=83910.0
Offline gtiscott
Re: vaccume hose
« Reply #2 on: 22 April 2008, 14:10 »
cheers mate, so theres no chance of them comming loose, ebay here i come :grin:
Offline mark3valver
Re: vaccume hose
« Reply #3 on: 23 April 2008, 19:37 »
no... they are quite a tight fit so are fine.....
Offline gtiscott
Re: vaccume hose
« Reply #4 on: 23 April 2008, 20:20 »
cheers, got some today, can't get the scuttle panel off now :angry: one of the screws is all chewed up the others just seem to turn but not unloosen :angry:
Offline Pete Taylor
Re: vaccume hose
« Reply #5 on: 23 April 2008, 20:23 »
get some pliers and rip the things out when you've unscrewed them a bit, they won't break..
Make sure you replace all three vac hoses too
Offline gtiscott
Re: vaccume hose
« Reply #6 on: 23 April 2008, 20:48 »
Hi Pete, i have changed one of them so far, will do the others tomorrow when i can get the panel off....is one of them only about 2.5"long? and connected onto a thin plastic pipe?
Offline mark3valver
Re: vaccume hose
« Reply #7 on: 24 April 2008, 08:41 »
yeah and be really careful when taking it off of the crank case pressure control valve which is the black box coming off the manifold. I snapped the little nipple that the vac hose goes onto and VW wanted £60 for a new valve so I had to glue it back on which was fiddly and took me 3 goes to get it strong enough - think they jut go brittle over time..
this pic shows the two smaller one's, the 3rd goes from the throttle body upto the ECU - have fun getting the scuttle panel off  :drool:
Offline gtiscott
Re: vaccume hose
« Reply #8 on: 24 April 2008, 18:41 »
can't get the scuttle off :angry: :angry:and broke a bit off it while trying :angry:
scott
Offline mark3valver
Re: vaccume hose
« Reply #9 on: 24 April 2008, 21:14 »
how many of the annoying have you got off so far? all I did was unscrew them for a bit then grab them with grips and violently tug and twist whilst pulling away and they just come out.... b*llsh!t design really.... you wait till your trying to get it back in place   :laugh:
