Author Topic: vaccume hose  (Read 1995 times)
Offline gtiscott
Re: vaccume hose
« Reply #10 on: 26 April 2008, 15:11 »
managed to get the scuttle off......couldn't get the hose off the ecu and didn't want to force it incase it broke anything :angry: so had to just put it back together and will try again later.
only thing now is the scuttle screws don't seem to tighten up, do you have to get new ones when you take it off
Offline Pete Taylor
Re: vaccume hose
« Reply #11 on: 26 April 2008, 15:13 »
They won't tighten, as long as they hold the scuttle panel in place it'll be fine. The old vac hoses tend to go a bit crispy at the ECU end. The nipple the vac hose sits over is metal so it's safe to cut the old hose off with a stanley knife
Offline gtiscott
Re: vaccume hose
« Reply #12 on: 26 April 2008, 20:12 »
cheers Pete, will give it ago tomorrow again :smiley:
Offline LazyLunatic
  • MK3 20VT Project
Re: vaccume hose
« Reply #13 on: 26 April 2008, 20:41 »
was looking at doing this as i have some spare hose lying around. 1st i wouldnt know which were vacuum and 2nd, i cant get my scuttle panel off and it is slightly broke from when i tried taking it off!
if you get it done, let me know how it looks.
LL ;)
Offline gtiscott
Re: vaccume hose
« Reply #14 on: 26 April 2008, 20:59 »
as pete said you just unscrew  the screws a bit then yank them out with a pair of grips.. i was real hard on them and they didn't break :smiley: it is an easy job now that i know i can just cut the ecu bit to get it off
Offline gtiscott
Re: vaccume hose
« Reply #15 on: 27 April 2008, 12:27 »
job done and looks much better than the old stuff, hardest part was getting into the ecu one as is limited space...but well happy :grin: :grin: :grin:
Offline mark3valver
Re: vaccume hose
« Reply #16 on: 28 April 2008, 12:21 »
for future reference there is a nut that holds the ECU casing down which you can undo and literally pull the ECU out and turn it round so you can see what your doing.
Has it made any improvements to the running of the car?
want a pair of raceland buckets with model specific subframes for £150 delivered? go here
http://www.golfgtiforum.co.uk/index.php?topic=83910.0
Offline gtiscott
Re: vaccume hose
« Reply #17 on: 28 April 2008, 14:03 »
good tip as the ecu side is real akward to get into, i think it seems a bit smoother cause i noticed the ecu hose had perished quite badly.   one question, does the lenth of the hose matter? i.e does it matter if the new one is slightly longer or slightly shorter than the old one? (i kept it the same size but just wondered)
Offline mark3valver
Re: vaccume hose
« Reply #18 on: 28 April 2008, 18:34 »
not really a vacuum is a vacuum I suppose although if it went to far it might not work but you would have to go a long way for that to happen.
