Author Topic: What is this sensor?  (Read 2843 times)
Offline lordbigsack
« on: 30 March 2008, 17:49 »
As you can see from the pics the sensor is knackered.  Anyone tell me what its called?  thanks.  Its located below the 2nd spark plug.
Things I need (Mar 08): 1990 Drivers door in calypso green for 3door - someone must have one!
Things I have found: (Mar 08)Power steering pump bracket, sun visor clip
Offline clipperjay
Re: What is this sensor?
« Reply #1 on: 30 March 2008, 18:07 »
Knock sensor
Don't ask how much either you need one without a doubt!
Offline Jay
  • balding fat cvnt
« Reply #2 on: 30 March 2008, 18:47 »
resize that pic mate, it's a bit large  :laugh:
Offline wopdat
« Reply #3 on: 31 March 2008, 10:43 »
Definately a knock sensor... :smiley:
Offline russ-vdub
  • Once a Dub, Always a Dub
« Reply #4 on: 31 March 2008, 11:35 »
i didnt actually know that, cool, does orientation matter with these, cos mines on the piss?
Offline rombonie
« Reply #5 on: 31 March 2008, 11:43 »
Stick the wirer vertical but i don't think its to critical, IT does need to be torqued to the correct level, 20 nm from memory.
Offline Benrevs
« Reply #6 on: 31 March 2008, 11:44 »
Took me ages to find it in the pic! :grin:
Offline russ-vdub
« Reply #7 on: 31 March 2008, 11:46 »
hmm i didnt know that either, better get me wrench out, stick straight and torque him up (i'll check the haynes first tho ;) )..god engines have soo many things that need to be right!
Offline cняis
« Reply #8 on: 31 March 2008, 11:52 »
try the breakers or ebay for one in mint condition i.e. no breaks on the wiring or its insulation
one from a passat will do, but the lead is shorter (makes no difference)
dealers want £50+ for them (i checked last month)
i just got one in mint condition off ebay for 99p  :cool:
Offline rombonie
« Reply #9 on: 31 March 2008, 11:56 »
Aye, if its to tight it will be too sensetive and retard the timing, check the advance at 2500 revs, if it advances to +30 then its ok
